Question about Wesco Manufacturing Wesco Hydraulic Platform Lift - 750-Lb. Capacity
How do I add hydraukic fluid? - Wesco Manufacturing Wesco Hydraulic Platform Lift - 750-Lb. Capacity
    Genius:
  • 2,494 Answers
There is a rubber plug on the side of the ram which comes out fill to the level of the hole using jack oil .
Posted on Apr 13, 2016
I have a 3032E. It was leaking fluid from the front left axial. I tightened the fitting but I need to add fluid.
Sounds like either a rack and pinion (power steering/power steering fluid) or a cv-axle (sealed unit cannot add fluid/clicking around corners? - replace).
I hope this helps
Oct 28, 2017 | Cars & Trucks
Cannot add hydrostaic fluid.no plug.it was filled at the factory.how can i add the fluid.
Turn the machine on its side or back or front so that the bulk of the fluid will be at the bottom when you add it. Fit the hose to this part, extend the hose other open end upward as high as possible. The pour the fluid into the hose end, when hose is full put your thumb over it and swing that end onto its hose connection and fit it without losing liquid.
Dec 14, 2013 | managemylife.com
Transmission fluid hose burst, fixed it, add fluid now the car won't move...
Two litres? Unless you are outside the USA, transmission fluid generally comes in quart containers. If you only added 2 quarts, yes, it's very possible the fluid level is low. However, you don't want to add too much. There should be a dip stick for checking fluid level. Run the vehicle until the engine is good a warm, about 15-20 minutes, and then check the fluid level. Add as needed. But remember, don't add too much. Add a little at a time, as you get close to full.
Feb 05, 2013 | 1999 Oldsmobile Alero
My tranny is slippin and transmission is low on fluid where do i add?
to add transmission fluid,lift the hood.
look near rear of engine for a thin tube with a dipstick
NOT THE engine oil dipstick,.
to add transmission fluid,you will need a narrow funnel that will fit in dipstick tube.
and that is where you add the fluid
Jan 04, 2011 | 1991 Ford F150
How do I add transmission fluid to a 1991 ford f150 standard transmission?
Add your fluid through the tube that your transmission dip sick come out of. Take out your transmission dipstick(make sure it is not the oil dipstick) put a funnel in the tube and add the trans fluid. Check the fluid when the trans is warm because trans fluid expands with heat and you want to make sure you don't overfill. Add small amounts at a time.
Sep 05, 2010 | 1991 Ford F150
1994 Crown Victoria: need to add brake fluid to master cylinder...
Why would you add fluid?
As the front pads wear,the fluid will go down, not an issue
If you keep opening the fluid resevoir,you will let moisture in.
May 05, 2010 | 1994 Ford Crown Victoria
How do i add transmission fluid to my 1996 camry?
If you have a dipstick under your hood for the tranny fluid, then fill it in there slowly... if not, you'll need to fill it through the filler plug that will be on the side of the transmission just above the halfway point
Sep 08, 2009 | 1996 Toyota Camry
!995 jeep gr cherk. transmission fluid. add hot
Its best to add while all is hot..
Leave it runing in park while adding fluid..
Put a little at a time and keep checking being careful not to over fill..
The dipstick mesures in pints - not quarts..
Rate well ;o)
Jul 22, 2009 | 1995 Jeep Grand Cherokee
Checking trans fluid level 4.7l 2001 laredo
First check your owners manual if you have one if not, then follow this proceedure. With vehicle in park & ignition off, open hood & remove the dip stick from the trans, should be some markings on dip stick that is stamped w/check in park or check in neutral. There will also be some hash marks, cold add/full, hot add/full. If checking cold, fluid levle will should be between the add & full, if checking the fluid level after driving, w/the vechile still running, check the fluid level w/the vechile in park or neutral, depending on what is stamped on the dip stick, check the hot level, should be between add & full. If fluid level at htis point is on add, then add 500 ml of fluid, check level again and add as needed.
Hope this is helpful.
Feb 15, 2009 | 2001 Jeep Grand Cherokee
Wesco Manufacturing Wesco Hydraulic Platform Lift - 750-Lb. Capacity Logo
505 people viewed this question
Top Wesco Manufacturing Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Wesco Manufacturing Plumbing Expert? Answer questions, earn points and help others
