Cars & Trucks Logo
Theresa Moss Posted on Apr 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the problem. 2002 toyota prius hybrid red triangle with exclamation, warning light, brake light, car with exclamation in the middle. Car has no power.
Lodhi Autos
Level 3:
  • Toyota Master 992 Answers
  • Posted on Sep 02, 2016
Lodhi Autos
Toyota Master
Level 3:
Answers
992
Questions
Helped
590458
Points
1808
It is called Master Warning sign. Get the car be scanned to know about the root cause of the problem.
4 Related Answers
Lovebytes
Dave Richardson
  • 10 Answers
  • Posted on Aug 21, 2008
SOURCE: 2001 Toyota Prius - A warning light with exclamation mark on a car appeared on the MultiVisual Display Unit
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
s60six
  • 328 Answers
  • Posted on Dec 15, 2008
SOURCE: toyota 2001 prius hybrid- warning signs
your owners manual should show all of the symbols and what they mean.I tried to get one to look at it but no luck...they should be in the manual though
toyotahelp
theodore ritter
  • 475 Answers
  • Posted on Aug 22, 2011
SOURCE: i have a red triangle
This the hybrid master warning light, which means the system has detected a malfunction, there are many causes that turn the light on, there are about 24 computers involved, the best advise I can come up with is that you have the toyota dealer check this and diagnose it, this may also still be under the powertrain or hybrid vehicle warranty
toyotahelp
theodore ritter
  • 475 Answers
  • Posted on Feb 18, 2012
SOURCE: have a warning light on the dash of my Toyota Estima Hybrid 2002. It's a red car with an exclamation mark in it. Flashes every now and then, then the engine switches off. Do you know what's ca
There are quite a few things that can cause this light to turn on and yes you are right it has something to do with the hybrid system, unfortunately this going to require that a suitable diagnostic scantool be connected that can communicate with all the onboard computers, this will retrieve any diagnostic codes that are stored, a technician can then start to diagnose the system based on the trouble code information.
Emergency energy warning light is on, what to do?
Hi
I think the hybrid system is not charging.you will need to get the car plugged into a computer and get the diagnostic done.
thanks
Red triangle with exclamatory sign in the middle came while starting my 2001 Toyota Prius Hybrid car
Orange triangle sign is called master warning light. When this happens get your car be scanned with the help of diagnostic computer to get to know the problem in any of the systems.
1helpful
What does it mean warning light TRIANGLE WITH SNOW on TOYOTA PRIUS 20 dashboard
There is absolutely nothing wrong with your car. It's actually keeping you safe! If the outside ambient temperature is +37F or lower, your car knows this and gives a warning for possible black ice conditions. Lots of people wonder the same thing, next time it shows the warning, note the outside temp to see if it's below +37F.
I hope this info helps!
~subyguru~
4helpful
2002 toyota prius warning light - car with exclamation mark
The light that looks like a car with an exclamation mark in the middle of it is the HYBRID WARNING light (see diagram below) You must scn the onboard computer network to determine why this light is coming on. You also need to scan your computer system to find out why the engine keeps dying. If the hybrid batteries are discharged, they must be properly recharged to prevent serious damage.
CAUTION: Read ALL service and warning lables in the engine compartment before attempting ANY type of service on a hybrid vehicle. The wiring harnesses that have ORANGE connectors are HIGH VOLTAGE connectors and can cause serious injury or death.
DO NOT touch any wiring harness or component that has a HIGH VOLTAGE warning label on it.
My recommendation is to tow the vehicle to a qualified hybrid repair center (preferably the dealer) and get it properly diagnosed and repaired. The high-tech, high voltage systems in this vehicle is nothing for anyone but a trained, certified technician to be messing with.
2helpful
I have a red triangle with ! inside it and red car with ! in the middle of it , so please i want to know this error in Toyota Prius 2008
1helpful
2answers
My wife is on a 6 hr trip home and her Check engine light, Red exclamation point with Triangle and warning brake light came off. We are new to hybrids but are trying to figure out if it will make it home....
The only fast solution is to drive to the nearest AutoZone, they will decode the engine light, and will give you a print uot of the code and code explanation, for free. After you will find out and decide to continue the trip or other options. Good Luck.
2answers
Check engine light comes on or more specific a car flashing red with a exclamation mark in the middle of it. will start then quit within 5 or 10 seconds its a 2002 toyota prius, battery seems fine
Acording the online manual , that is the Hybrid system warning light. I havn't tracked down exactly what it means , but is is grouped in with other service reminders. Will add more info when i find it " Google 2005 prius warning light " one of the first listings has a link to toyotapartsandservice.com
4helpful
2answers
9helpful
5answers
2003 Prius Hybrid System Warning Light
My Toyota Prius hybrid warning light has come on three times in eight years. If I turn the car off for 20 minutes, the hybrid light is off but the check engine light is on. After a while, the check engine light goes off. I think this problem is related to moisture somehow entering the hybrid vent on the driver's side. All three times this has happened, the weather was wet. Kevin Cardiff
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
