Question about Pacific Coast Imports Cl-150 Aquarium Water Chiller
Light flashing and tempature fluctuations - Pacific Coast Imports Cl-150 Aquarium Water Chiller
Heating is not working on my 2008 saturn aura was working fine then it just stopped now it comes an goes an my temperature gauge is fluctuating between hot an cold but the car is not overheating...what is...
check coolant level sound like engine low on antifreeze.make sure coolant overflow jug coolant level full cold mark.if overflow jug empty more likely radiator low on coolant allowing air in the cooling system.
Oct 22, 2013 | 2008 Saturn Aura
2006 PT Cruiser. All dash light indicators flash on and off and all gauge needles fluctuate simultaneously. Sometimes when this happens the car stalls. The dealership can't find the problem. Does
I just had the same problem happening with my 2006 PT Touring. Took it to the dealership. The issue was the electric parts of the ignition switch. They replaced it and all is well in the world again.
Jun 18, 2012 | 2006 Chrysler PT Cruiser
The abs light and brake light is on the speedometer does not work until i hit 30. the tempature gauge fluxuates from 210 to almost the 260 and then goes back down to 210. What is causing these issues?
This is most likely 2 problems. The ABS/Brake light and speedo issue will be the speed sensor located in the read differential housing. The temp guage issue (and I'm assuming this is at idle) could be thermostat or temp sending unit. The fluctuation is causes by the electric cooling fan cycling on and off to control the temp. However, most of the time this fluctuation should be from about 195 - 220 degrees.
Aug 15, 2011 | 1999 Dodge Dakota
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
Range over heats and flashes error code f3-e2 Whirlpool
That is a bake range over tempature error. First try disconnecting the power to the range for more than 10 minutes and see if the error re-appears. If it does then you will need to test the tempature probe with an ohm meter. At room tempature the probe should test 1000 to 1100 ohms. If you get a reading that is out of range or different ohms than rated replace the probe. If the probe tests good then replace the control.
Jan 17, 2010 | Whirlpool Ovens
The oven starts to beep and flashes F2 when the
the f2 is telling you that the tempature is to high. It could be your control board. I personely would call a tech as its got to do with the contacts on the control board or the door lock. can be several different problems.
Nov 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My 2000 VW Cabrio tempature light is flashing. I
you will probably need to replace the tempurature sensor it's self the car is not actually getting hot.
Oct 02, 2009 | 2000 Volkswagen Cabrio
Tempature flactuate most of the time. I have been told that main board is faulty
Check the CPU fan RPMS if they fluctuate over a wide range or the fan makes a louder then normal noise then the fan is probably going bad.
Jul 29, 2009 | Computers & Internet
Oil tempature gauge fluctuates sporadically
NO.... BUT THEY COULD HAVE COMPROMISED THE WIRING OR SWITCH AT OIL FILTER AREA
Jan 13, 2009 | 1999 Nissan Maxima
2004 VW bug: Has episodes when coolant temperatue light flashes.
Check or replace the tempature sending unit located on the engine block.
Dec 19, 2008 | 2004 Volkswagen New Beetle Convertible
Pacific Coast Imports Cl-150 Aquarium Water Chiller Logo
635 people viewed this question
Top Pacific Coast Imports Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Pacific Coast Imports Fish Expert? Answer questions, earn points and help others
