How to fix the drainage knob with the cord - Washing Machines
  • 1,162 Answers
What do you mean with a cord?
Posted on Apr 03, 2015
    Top Expert:
  • Washing Mach... Master
  • 42,881 Answers
Sorry but the question makes no sense to me . cord ???? drainage knob .
Can't remove Zanussi ZWN7120L filter
seems that something is stuck inside the filter, maybe turning the washmasine upside down would help, but i would rather call a service
Apr 09, 2014 | Washing Machines
Recoil spring on craftsman profession 30 Ft cord reel
On the right side of the housing is a cover. In the center is a hex shaped knob. Hold the knob while removing the cover screws. Once the cover is loose release the spring pressure on the knob. Then you can gain access to the rewind assembly. To reinstall, start with 6 rotations of the knob to put the proper stress on the spring.
Nov 17, 2012 | Garden
My mower deck will not hold adjustment
I had the same problem. I fixed it by wrapping one end of a bunge cord around the adjustment knob and the other end to the tractor frame. The pressure from the bunge cord holds the knob against the height adjustment slots. Give it a try.
Aug 22, 2012 | John Deere Garden
The "drainage blocked" is on.
ON THE LOWER FRONT OF THE MACHINE THERE IS A COVER THAT CAN BE REMOVED
WITH A COIN OR SCREW DRIVER ---- HAS 2 TWIST SCREWS HOLDING IT ------
ONCE REMOVED YOU WILL SEE A DRAIN PLUG ON THE LEFT LOWER CORNER --
THIS HAS A PLASTIC TURN KNOB THAT OPENS BY HAND ... SOMETIMES A BIT HARD TO OPEN BUT TURN KNOB LEFT AND WILL OPEN ....... WATER WILL START TO LEAK OUT AS YOU OPEN THIS BUT DON'T WORRY -- THIS HAS TO HAPPEN --- NOT ALL THAT MUCH WATER BUT BE PREPARED TO MOP IT UP ......... NEXT PULL THE DRAIN FILTER OUT FROM
THIS OPENING AND WASH IT OUT ... ALSO REACH IN TO THE OPENING WITH FINGERS AS
THERE MAY BE SOME BLOCKAGE BEHIND THE FILTER AS WELL.. BE CAREFUL NOT TO
DAMAGE THE PLASTIC PROPELLER DEEP INSIDE THE HOLE , THIS IS WHAT SPINS AND TAKES THE WATER OUT OF THE MACHINE ....... VERY EASY TO DO ---- JUST NEED TO
DO IT ONCE TO UNDERSTAND THE PROCEDURE... UNPLUG MACHINE BEFORE CLEANING ................
Jun 10, 2011 | Bosch Washing Machines
Westinghouse undercounter dishwasher. after shutting door with latch, comes on when dial knob turned to selected wash. was taken out to redo floor underneath. after being placed back in position, did at...
This seems to be a drainage problem, obviously.
There may be some food debris in the drain tube where it connects to the drain pipe. It would be easy to detach and do a visual check, and see if you can clear the clog. Also, try to see if the drainage hose is kinked in anyway that would restrict water flow. If that doesn't work, please don't hesitate to message back with more details!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 18, 2010 | Dishwashers
Cycle will not advance
ok turn off unit at power switch, turn knob to drain and spin, and turn back on that will reset its programming and force it to do the drain and spin cycle also check the drainage hose to ensure it's not kinked or clogged. If it's clear and in good shape
Jun 29, 2009 | Washing Machines
Drainage
Turn off the hot and cold water supplies and remove the power supply cord from the outlet. Remove the lower front panel by removing three torx screws, one located at the lower left corner, lower center, and lower right corner. The panel removes easily. Located at the bottom center of the cavity is a large ivory colored filter with a turn cap. Get a shallow container or alot of towels, and slowly turn the slotted cover to the left a little at a time until no water runs.  Remove the filter and any debris that may be inside. Wash and dry the filter and replace, tightening the cover securely. Replace the lower panel, turn on the water supplies and plug in the power supply.  This should solve your problem and also relieve any standing water in the drum following a wash.  You may want to do this every 3 months or so as this is an easy fix
Sep 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Saeco royal cappuchino ventilate
Alternatively, try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Jun 30, 2008 | Saeco Royal Professional Espresso Machine
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
