Question about Audiovox PPC-6601 Pocket PC
Powering off when using Internet
Every time I access the internet at all on my phone, it shuts off about 30 seconds into the explorer. What can I do to fix/prevent this problem?
Re: Powering off when using Internet
Posted on Dec 08, 2007
0 characters
3 Points
I am getting the "unable to access ebook store Check your network settings to ensure you have access to the internet." i am using Windows 7; Sony reader PRS-600 Would appreciate help! Thank you Joanne
Has this happened to you before? If you access the Reader Store from your regular Internet Explorer can you access it? If that is the case, try downloading the Reader Library software once again.
Jul 11, 2010 | Sony Reader Touch PRS-600
Internet explorer is not working, while opera is working
opera has a bug it did the same thing to me it would work for a few days then shut my internet do delete it it is not good for the phones
Dec 05, 2009 | HTC Tilt 8900 Smartphone
Want to use my htc mogul phone to access the internet with my lap
Using pdanet from June software you can use phone as modem..with laptop. June software is $29 one time (make sure you get the windows mobile software if you have a mogul) or sprint will charge you $15 a month. Also with june software make sure you have unlimited data plan. Ive been using june software for about 4+ problems.
Nov 12, 2008 | HTC P3600 Pocket PC
How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Jul 29, 2008 | HTC Touch P3452 Smartphone
Shadow not connecting on internet sharing..
Uninstall ActiveSync.
Download ActiveSync 4.5 from Microsoft.
Install ActiveSync
Do not connect the phone to the PC via USB yet.
In the phone, goto Internet Sharing, select the internet connection and select "USB", and click connect.
Afterwards, connect the USB to the PC.
Wait up to 30 seconds and vola! You have internet access.
Jul 07, 2008 | HTC Shadow Smartphone
Cannot access secure sites using Internet Explorer on HP Jornada 720 running HPC 2000
Download and install HPCTweaks2k2v06.exe then apply the "identify PIE as IE 6.0"
May 25, 2008 | HP Jornada 720 Pocket PC
Trying to find out away to use the internet explorer
go to the store where you bought your phone from and ask them if they can give you another cell phone for free.
Apr 20, 2008 | Samsung Blackjack SGH-I607 Smartphone
Please note that when you want to use pocket (IE) browser of your PPC (pocket PC) phone; you need to ensure GPRS setting has been made in your phone.
For GPRS setting (Example: Airtel India network) please do the following steps.
Start --> settings --> Connections(tab) --> Connections(icon) --> under My ISP tap on "Add a new modem connection" --> enter connection name: airtel --> select a modem: Cellular Line (GPRS) --> access point name: --> leave blank on username, password & domain --> Finish.
If you are using different network (sim card) then you need to get "access point name" information from them.
Dec 27, 2007 | i-mate PDAL Pocket PC
Internet Explorer won't launch after a hard reset
Is it picking up a good IP address? Are the access points encrypted? You would need to set up the Wi-Fi on the PDA to the specifications of the WAP. if Internet Explorer is not loading, I suspect that there is a problem either with the image in ROM or else with the part of the RAM which is used to hold user data for Internet Explorer. Have you recently upgraded the ROM? The upgrade may not have worked properly perhaps. Maybe try a reflash of the ROM image. Do you get any error message or does the operating system go round in a loop and never come out?
Sep 14, 2005 | HP iPAQ H5450 Pocket PC
Sort out my VPN issue
On my 4350, if I go Settings -- Connections -- Tasks, there's a task "Set up a new VPN connection," which will walk me through network IDs and authentication. I worry that that isn't there in WM2003SE, but have a look. As to your second question, one serious flaw to the current communications software is that there's no way to save multiple settings sets. So when you're home or go to a public hotspot you'll likely have to empty out all your office settings, then re-input them when you're back in the office. Good luck.
Sep 11, 2005 | HP iPAQ HX2750 Pocket PC
Audiovox PPC-6601 Pocket PC Logo
Top Audiovox PDAs Experts
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox PDA Expert? Answer questions, earn points and help others
