How can I kill roots in a sewer pipe?
Roots blocking my sewer pipe.
  • Amanda Drew
    Amanda Drew Oct 05, 2017
    My sewer line is all backed up, and it's making a gross smell in my bathroom. Maybe it's plant roots like what's happening with yours. I bet that if we both got a professional repair service they'd be able to get rid of those roots and maybe even fix the sewer line if it was damaged.http://www.goldsealplumbing.com/leak-rep...
  • 693 Answers
Lodger, you're in kind of deep on this one.
Killing the roots would be only the first step in solving your problem.
There is obviously some physical damage to your pipe as well which would have to be repaired to prevent raw sewage from leaking.... somewhere. Over time this could easily lead to a sinkhole.
I'd call a Pro if I were you.
Sorry I couldn't be the bearer of better news.
-Steve
Posted on Apr 03, 2015
  • 7,733 Answers
Zep 2 lb. Root Kill is an effective solution for ridding your sewer pipes, drain and septic field lines of shrub and tree roots. Plant roots can penetrate through small cracks and poorly sealed joints of sewer lines. If not controlled, these small roots will continue to grow larger causing breakage, reduced flow, and eventually flow stoppage. Root Kill's powerful granular formula dissolves these pipe-clogging elements on contact without harming the target tree or bush.
  • Dissolves septic systems clog-causing roots
  • Powerful granular formula dissolves roots without harming shrubs or trees
  • Protects pipes from corrosion
  • Promotes root and fungus control within sewage system
  • Childproof cap
ZEP 2 lb Root Kill ZROOT24 The Home Depot
Testimonial: "Many thanks to you all - will give them a try."
  • Washing Mach... Master
  • 3,957 Answers
You can use chemical treatments, but they will not show immediate results. Recommend calling a plumber to cut the roots out, and then treat with a commercial product such as RootX. Here are some links about other treatments:
I LIKE TO BUY SOME HOT HIGHLANDER HERBAL ROOTS WINE IT IS A PRODUCT OF POLAND ANY IDEA WHERE I CAN BUY IT
NV Hot Highlander Herb Roots Poland Red search ... - Wine Searcher
www.wine-searcher.com/find/hot+highlander+herb+roots+poland+red/0
Showing 'Hot Highlander Herb Roots Poland Red' search results. Compare prices for this wine, at 17000+ online wine stores.
NV Search Hot Highlander Herb Roots Poland Red wines
www.wine-searcher.com/find/hot+highlander+herb+roots+poland+red/0/-/-/x
Search results for 'Hot Highlander Herb Roots Poland Red'. Wine prices & availability at all online stores.
Hot Highlander `Herbal Roots` - GraysWine
www.grayswine.com.au/.../highlander.../wine/hot-highlander-herbal-roots-wine-6-x-1... Hot Highlander `Herbal Roots` Wine (6 x 1L), Poland. ... Produced from a traditional recipe, Hot Highlander - Herbal Roots contains extracts from herbs, roots ...
Hot Highlander `Herbal Roots` Wine - GraysOnline
www.graysonline.com > Auction Product : highlander-118025470 Hot Highlander `Herbal Roots` Wine (6 x 1L), Poland. Description: Hot Highlander has been a well - known and well - loved beverage for centuries, due to its ... HOT HIGHLANDER HERBAL ROOTS WINE, POLAND Google Search
Jun 25, 2017 | Furniture
When I flush the toilet upstairs the toilet in the basement "burps". The water goes down the drain . What causes this? and how would I fix it
at this point it indicates a blockage in the pipes after the bottom pan
could be tree roots, waste, grease and fats from the kitchen /bath
try using a quality caustic soda product to destroy fats , waste and other organic material
other than that get in a plumber with a worm and cutter to remove build up/ roots from the pipe
if this problem is new in an established system it needs cleaning out but if is new in a new house , get a plumber to rectify the plumbing layout
Jan 02, 2017 | Home
Want to kill grass is vinegar by itself enough ot do i add water to it
One quart of vinegar -- with 20 percent acetic acid -- mixed with 4 ounces of lemon juice will kill the above-ground portions of the weeds and grass. The foliage, flowers, buds and stems will wither, dry and die, but the weed's roots are left intact. For a tougher weed and grass kills, combine 1 tablespoon of 20 percent vinegar, 1 tablespoon of gin, 1 quart of water and 1 teaspoon of dish soap. This mixture kills the above-ground and below-ground portions -- including roots -- of the weeds.
Oct 14, 2016 | Miscellaneous
How to treat fungus on tree roots
use some spray root killer wait for then spray root kill on them for 5 day then wait for the to die if roots are on top of ground were you can see them cut in out with milwakie recipricating saw you cut all the root sticking out of the ground through away
Sep 04, 2014 | Health & Beauty
Roots in sewer line
uh oh that's bad, you have roots growing in the sewer lines, more info is needed here
Mar 07, 2014 | Jet Plumbing
I had my drain snaked out and a camera put in to see if there was a problem, I was told the pipe must be cracked although he said he could not get the camera all the way down. After snaking out roots and...
Did you see them pull out the roots? The camera has become a sale tool that makes a great deal of money. If I were you I would sit on the job and not do anything right now.
If and when it stops up again you need to watch them work. Check the cable they are going to use and make sure there are not roots on the cable from an other job. Then watch them run the cable if they dont pull back roots. You dont have roots.
If they do pull back roots then you must chose to kive with the cost of snaking out the line lets say every year or 6 months. If that the case you need to ask your self how long am I going to stay here,
It might be cheaper to clean the drain out for 200.00 than to spent 10.000.00 for a new line.
I am not saying that 10.000.00 dollars is your number depending what state you live in will control the cost.
But a rule of thumb would be anywhere from 100.00 per foot to 200.00 per foot. Get 3 prices you can do that over the phone. Just ask the guy who you are talking to now and ask him or her " how long of a run is it?" so then you have your footage the ask him his price per foot.
Best of luck Dont get taken and if you replace the line tell them you want a permit and a copy of it and the inspection card.
Best of luck RJ
Sep 08, 2011 | Plumbing
Sewer snake has a ball of roots in city main and can not be retrieved. Tried many times by reversing with no results?
harnmar-
Unfortunately you are left with few options. Is there access to the city main? If someone can get to the root ball from that direction, they may be able to avoid two less desirable options, which are 1) dig you're way to the pipe, bust it open and free the snake that way, or 2) pull the snake with a winch until it either breaks loose, or snaps in two, and risking busting some plumbing in the process. If the snake snaps you may have to (gulp) dig it up. A third option, if the snake and root ball aren't causing sewage to back up, is to leave the thing in the pipe...this may be delaying the inevitable, however.
DIYpro
Jun 09, 2011 | Garden
Ejector pumps started to go off frequently
The ejector pumps probably pump to the same sewer pipe you had rooted. Rooting can do damage. Trees can break into your sewer pipe, jam them up with roots, and let ground water in. The ground water may be following your sewer pipes on the outside back to your house. It costs a lot, but you can have your pipes examined with a tv camera, the rooter people can do that. Make sure your ejectors have check valves, and they are working right. It's easy for something to get stuck in the check, and then water will come back.
May 01, 2009 | Zoeller E282 Nonautomatic Waste-Mate
New American Standard Flowise toilet won't flush
You have a sewer issue....it is entirely possible for other things to cause the toilet to loose water as they drain....but only if there is a sewer problem.....that is why there is an air gap between the toilet and the tank...(the trap) now I have been in this industry 35 years and the jet you speak of is in the bottom of the toilet that directs and forces flow down and out of the bowl as do the many small holes on the underside of the bowl lip ( I suspect ...as I have seen it MANY MANY time in the paste) that your old bowl may have had lots of calcium or lime build up (using lime a away occasionally helps) in the holes under the lip as well as other places...which reduces water flow and there by reduces pressure......but what you are describing is definitely sewer related....other water sources causing water to drain...bubbles...etc..I had a similar problem that occurred about once every 2 years in one of my homes...I had a tree root growing into my sewer line ...it would flush but on occasion...debris would get caught and a good plunging would help...but eventually...(twice) I had to rent a 3/4 inch snake from Time Rental...with a cutter head on it and remove the problem. Now your problem sounds exactly like an air gap problem...in that an overflow or something related is causing a vacuum assist when large amounts of water are drained...(ie...tub...washer...).as this happens the force the water carries and the lack of access to air in the flow causes vacuum "tugs" on other water sources attached to the sewer....take of your clean-out cover (usually in the back of the house and if you see water standing in it ....sewer problem....also you can have someone flush the toilet and eyeball the sewer/overflow...to see how it drains.
I hope this helps....good luck...thank you for rating my effort...the Fang.
Mar 27, 2009 | American Standard Colony 2388.012.222...
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
