Question about Refrigerators
My fridge freezes everything on the bottom, it never stops, I had to disconnect because everything was frozen
  • 7,733 Answers
Testing the Thermostat for Electrical Problems Again using the wiring diagrams, determine which of the wires coming from the thermostat supply the power to the compressor motor's start relay switch. To check the thermostat, you will need to take a continuity reading through the thermostat's main contacts. To do this, set the function on your DMM to the R X 1 function, insert the test probes into the holes on the harness plug associated with those wires and rotate the knob on the thermostat through its full range. In the thermostat's "OFF" position, the meter's LCD should display an "O.L." and then, as you rotate the knob clockwise, the LCD should display a "0.000" if the thermostat is functioning properly, electrically. If you get a "0.000" reading even in the "OFF" position, the thermostats internal contacts are stuck in the closed position, and you need to replace the thermostat.
Defective Temperature Sensing Tube If the thermostatic control checks out electrically, the problem lies with its temperature sensing tube or bulb. This tube contains a gas which condenses as it get cold. As the gas volume decreases, the spring loaded contacts open, shutting the compressor off. There is no way to recharge the sensing tube once it has lost its charge, so you will have to replace the complete thermostat control.
Posted on Apr 03, 2015
Testimonial: "where can I buy a new thermostat control??"
  • Doctor PC
    Doctor PC Apr 14, 2015
    Depends on you frige brand. here is a googoling limk -https://www.google.com/search?q=thermost...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Fridge is freezing stuff
try to call a technician the defrost system of Ur fridge might be damaged or u have a leak of gas on ur system.. tell him to check the thermostat.. also
Mar 09, 2009 | Candy CPCA270FFK Bottom Freezer...
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
