Question about Garden
Blows fuse after start up. Need wiring Diagram or ez solution.
  • Eugene Rounds Apr 23, 2015
    Hi Norman , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Would need make and model to look for the diagram.
    Sergeant:
  • 462 Answers
Check wiring sounds like one has worn and grounding out
Posted on Apr 23, 2015
Applies brakes and blows fuse changed out brake light switch and still blows fuses
You have a dead short in the wiring to the brake lights, you need to get a wiring diagram and trace the wiring to find the short, no quick fix for this type of problem.
Sep 29, 2016 | Cars & Trucks
Brake light fuse blows
Hi Anonymous, obviously you have a dead short, hook one lead of an ohm meter up to the out bound clip of the blown fuse. Clip the other lead to a sharp pointed scribe and start stabbing the wire from the fuse it keeps blowing untill the ohm meter quits reading zero and reads infinity and there or very close by is your short. For a wiring diagram go to: http://www.stcharlesharleydavidson.com/OEMpartfinder.htm#
enter your year and model then scroll to the " W " for wiring diagram. Good luck
Apr 13, 2014 | Harley Davidson FLHX Street Glide...
2007 Ultra Classic - Tour pack removed. Blows tail
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Oct 22, 2013 | Harley Davidson Motorcycles
Diagram of a 2000 chevy express wiring of a starter
( one question i have is every time the ignition fuse blows do i need to replace the starter relay? ) NO ! You have a dead short to ground on one of the circuits that fuse feeds. Do you know how to find a short circuit ? Video's on youtube show how. The fuse that blows ,is it IGN - A 40 amp. located in the under hood fuse/ relay center ? That fuse feeds B+ voltage to the ignition switch ,which powers up other thing's ,fuse's etc.. Not just the starter relay ! I see five other fuse's that get power from that fuse when ignition switch is in the start or run position . In the I/P fuse panel the gauges fuse #4 10amp , air bag fuse #10 10amp , turn b/u fuse #16 20amp. , Plus trans fuse #20 10 amp ! Pull out these fuse an try to start the van. if the ignition fuse doesn't blow the problem is in one of these other fuse circuits. There is one more fuse that get's B+ power from the ignition switch and ign A fuse ,crank fuse fuse #8 10amp. this powers the control side of the starter relay .
You can find a free wiring diagram here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine . Under system click engine , under subsystem click starting. Click the search button then the blue link.
If you pull those fuse's i mention and it still blows the fuse look for a shorted ignition switch or wiring from ignition to the starter relay , not the relay itself. Park neutral safety switch . Isolate the circuit , pull the relay out of it's socket ,pull the crank fuse #8 in the I/P fuse box. with a ohm meter check to see if that part of the circuit is shorted to ground. Do you know how to do that ? Do you have a volt ohm meter ? You can buy one cheap at parts store .
Sep 14, 2017 | 2000 Chevrolet Express Cargo
2010 MB Sprinter starter fuse blows every time ignition is turned on. Help...
mercedes service letter:
http://www.aev.com/uploads/file/SPRINTER%20NO%20CRANK%20NO%20START%20.pdf
Replace with 25 amp fuse.
Oct 04, 2012 | 2010 Mercedes-Benz Sprinter
Don't know what fuse is what .10 amp blows right
try different fuses starting with lowest then go up but think it is a 30 amp fuse ?
Oct 08, 2009 | 2001 Jaguar XJ8
99 dodge neon # 10 fuse ing feed 15 amp blows out
There's a short in the circut. Check continuity of the wires that feed from that fuse (you'll need a wiring diagram to identify each wire). You've got something that is causing too much amperage to move through the circut and the fuse blows. Make sure the amperage on the fuse is correct for the application (your owner's manual or fuse box diagram should tell you what amperage rating to install in each fuse slot).
Jul 03, 2009 | 1999 Dodge Neon
Veh wont start
by looking at the wiring diagram for your truck. the pcm1 fuse only feeds the pcm so most likely it is a grounded wire between the fuse block and pcm. follow the wire harness closely between the two and see if its grounded somewhere. also try disconnecting the pcm and see if the fuse still blows. that would isolate the problem to the wiring. it is highly unlikely that the pcm would cause the problem.
Nov 27, 2008 | 2004 GMC Envoy
Wiring Diagram for 2005 Ford Ranger XLT
I have wiring diagram. Respond with your email address or fax number and I will sent it to you.
Sep 18, 2008 | 2005 Ford Ranger
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
