Question about Exercise & Fitness
I have a bodyrider brt3880 elliptical. I keep getting a flashing e1 message and can't use
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
I have a BH Fitness Inspirit Program Cross Trainer and about 20 seconds after I turn it on an E1 flashes on the screen. Can anyone help please ???? Thanks
the problem is there that for BH INSPIRIT cross trainer the machine uses a small part inside a complicated gear box that pulls the wire for the magnetic wheel at this gearbox there is a sensor that reads the state of the gearbox and send it back to the computer(display) if the sensor get some issue and its sends wrong data back it displays E1 error message so i recommend that you contact your dealer or supplier and ask them to send you that part and instructions how to open your elliptical cross trainer and replace it your self
in 95% it could be that one in the other 5% it could be the computer it self cant read correct the data
I am very sorry to hear that hope you can fix it
Jul 09, 2011 | Sport & Outdoor - Others
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
Error message "key depressed" and no resistance on elliptical.
you will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
Error E1 mean?
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
http://www.appliance411.com/data.php?rc=548392
pls rate my suggestion...
Jun 26, 2009 | Whirlpool Washing Machines
Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Exercise & Fitness Logo
449 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
