Question about Retail Supplies
Alarm sounding, showing E mode and wont let me do a Z reading
  • 592 Answers
It means the previous transaction was not finalized. Turn your key back to R and press Cash/tend button
Posted on Jun 02, 2015
My Ademco Lynxr-EN went into alarm mode with a number 29. On reading I see code 26, 27, 28, 29 mean low battery pack but what if just number 29 and it shows alarm not just low battery?
multiple low battery ones in sequence , mean a remote low battery. There is usually only one reporting zone on the remote (panic). That would be why only one zone shows alarm.
May 12, 2017 | Ademco Home Security
Beret 2 way 5000m alarm siren problem.
These Alarms are so very fickle. If the Alarm lasted a year, then you are out of warranty and I have removed more than my fair share of Alarm's. As the Vehicle owner, you need to realize that your problem is quite common and you should be grateful it has not complete immobilized your bike. My Recommendation is... Remove it and return it to Stock or spend the money and get a higher quality alarm with a great reputation. Don't truck the Install Shop, they get tied to one brand, find the Alarm that meets YOUR NEEDS...
Mar 03, 2014 | Motorcycles
Wont get up to speed
sounds like the ecm has it in limp home mode. If the truck is later than 1996 you can put a scanner on the down link and read the code. If not go on you tube and see the video on how to check prior models for the code.
Feb 07, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
    With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
    Aug 27, 2010 | Vacuums
    Having alarm clock sound even in vibrate mode
    It is not possible to sound alarm in vibrate mode, but by going into master volume and setting it to sound alarm only, the alarm sounds in silent mode.
    Jan 10, 2009 | LG Cell Phones
    How to set date and time on a sports cardinal watch
    Hold the mode button down for about 3 seconds or until the alarm time starts flashing. Use start/stop button to select what number on the display to change. Use reset button to change the number. Push mode button again to return to normal operation.
    To change the time, hold the mode button down for about 3 seconds until the numbers flash. Then release mode button and then press it once again. The time programming screen should be showing. Use start/stop to select the numbers on the display to change. Use reset button to change the number. Use mode button to exit programming.
    Dec 29, 2008 | Cardinal Airlife Brand Misty Max 10...
    Lost manual for a timex t307s
    Setting the Alarm 1 for AM/FM Radio
    1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
    you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
    need to press the 2 Radio Alarm 1 Button again.
    2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
    seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
    3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
    L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
    more information on programming radio stations into memory, see the Programming Radio Station Settings section of
    this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
    4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
    set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
    is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
    flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
    5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
    Indicator
    will appear on the display, showing that the radio alarm has been set.
    Setting Alarm 2 for Nature Sounds/Buzzer
    1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
    Indicator appear on the display.
    2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
    3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
    Sound #1: Ocean Surf
    Sound #2: Birds
    Sound #3: Brook
    Sound #4: Wind Chimes
    buz: Buzzer
    4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
    5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
    display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
    Nov 18, 2008 | Timex (T307S) Clock Radio
    T307S How to deactivate the alarms
    Timex T307S
    I lost my manual also so had to resort to relentless trial and error.
    The problem with the alarm is that it is too easy to turn it on.
    The 1 and 2 buttons on top of the unit with the alarm clock symbol turn each alarm on or off. Your only cue is on the display in the top line of the display which will have a bell followed by “RADIO” or “SOUNDS”, if the alarm is armed. If you see this symbol and want to disarm the alarm, press the 1 or 2 alarm button according to which alarm was on the display. It’s just as easy to turn the alarm back on either deliberately or accidently
    Enter Alarm Setting mode by holding the 1 or 2 alarm button for about 2 seconds.
    Display will flash – in this mode you will be able to do the following
    Date Set Button – changes between Everyday/Mon-Fri/Sat-Sun
    Arrow Buttons – adjust the time setting
    Alarm 1 (Radio):
    Mode Button – changes between AM/FM1/FM2
    1-6 Buttons -- changes between stations
    Alarm 2 (Sounds):
    Mode Button – changes between SD1/SD2/SD3/SD4/Buzzer
    If you don’t change any settings for about 5 seconds the unit exits the alarm setting mode.
    Timex already has your money so I guess they are not motivated to publish their manual.
    Feb 08, 2008 | Timex (T307S) Clock Radio
    Retail Supplies Logo
    78 people viewed this question
    Top Retail Supplies Experts
    Electroboy
    Electroboy
    Patrick Tinashe...
    Are you a Retail Supply Expert? Answer questions, earn points and help others
