Where do I plug in the cable wire on norcent tv?
Norcent Technologies PM-4201 42 in. EDTV-Ready Plasma Television that turns itself off within one second. Then the remotes don't work and I have to unplug the tv. Is the tv shot?
That might be a factory fault don't hesitate but to take it to the retailer if still under guarantee. Or phone the manufacture for a quick respond.
May 03, 2017 | Norcent Technologies PM-4201 42 in....
Why can't i connect my windows 7 laptop to my tv
you must see the owner manual from your laptop or TV how to connect
However see this diagram.and proceed according.
God bless you
Oct 17, 2012 | Norcent Technologies2703 27" TV
Can i get tv stations on teh surround sound or just the dvd sound
plug a red and white AV cable into your output sound on your television and connect the other end into the aux 1 or 2 on your norcent amplifier and choose the aux 1 or aux 2 button on your remote
Feb 17, 2012 | Norcent Technologies DP1800 System
Please i need manual for norcent lt-3751 lcd 37" tv because this tv dont power on
Make sure the power cable is plugged into the T.V. and the wall outlet. If it still doesn't power on try a different outlet. If that still doesn't work then there might be a problem on the board that needs repaired.
May 05, 2011 | Norcent Technologies LT-3751 37 in. LCD...
What is the norcent tv romote code for time warrner cable???
Looks like Time Warner uses basically 9 different remotes. Not knowing which one is yours im giving you the link so you can choose which remote is yours and find the codes.
I check one of them and found these codes 1089, 1589, 1590, 1365, 0748, 1591, 0824 for Norcent so I bet you will be up and going in no time.
Click the link. Click the picture of your remote then select device which is tv then select brand which is Norcent. It also gives you complete instructions on how to program the remote.
Good Luck!!!
Nov 25, 2010 | Norcent Technologies Televison & Video
I have computor with Norcent LM 965WA monitor. Really liked the fact it had built in speakers. Worked great, now when I plug in the wire from compuitor to monitor, static but no sound. Any suggestions...
Hi and welcome to FixYa,
With your indulgence, pls verify that it is indeed the built-in speakers of the Norcent that is the issue. Temporarily plug in to the computer a pair of headphones or even an old external computer speakers. If sound, then the monitor speakers are verified, if likewise static, then it is a computer issue.
Let's try the easy one's first:
  • check/replace the cable;
  • try other ports to plug it in at the computer;
  • determine if the sound device/driver for Norcent shows up in your Device Manager;
  • determine if on Sound Property in COntrol Panel, the Norcent is selected as the default device;
  • you may want to update the firmware and driver available here.
Would appreciate a postback for any updates on any development(s) (or even the lack of any). Pls include what Operating System you are running and if the Norcent is using USB connectors or standard cables. Good luck and thank you for using FixYa.
Mar 09, 2009 | Computers & Internet
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
