Question about Brother Office Equipment & Supplies
What is the possible solution in unit unable 30 problem maintenance appeared in my printer message in my brother dcp 150c
Brother dcp-150c unable clean 46.how can troubleshoot this problem? plz help me. thanks
To help you troubleshoot the error 'Unable clean 46', please follow the instructions given below:
- Pull out the AC plug.
- Put back the AC plug while holding down the 'Menu' button and keep holding it (15 sec).
- Now you are entering the 'MAINTENANCE' mode and 'Error 46' pops up in the display.
- Select 8 by using the arrow buttons ,push OK and select 0 and push OK.
- 00:00 00:01 OK (the display is showing this message).
- Now push the 'MONO' button 25 times until you see PURGE: xxxxx
- Select 2, push OK, select 7,push OK,select 8,push OK, select 3,push OK.
- The purge counter indicates now: purge: 00000
- Switch OFF the printer and wait for 1 minute and Switch it ON.
- Now try to print.
If issue persists, it is recommended to contact Brother Support Center for further assistance from the link given below:
http://support.brother.com/g/b/contact.aspx?c=au&lang=en&cid=2&pcatid=4
GuruAid.com
Jun 08, 2016 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
My brother dcp 150c doesn't print the red color
my brother dcp 150 when going to print it says unable to print any help?
Aug 22, 2012 | Brother DCP 115C All-In-One InkJet Printer
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
CLEAN UNABLE 46
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Feb 25, 2011 | Brother DCP 130C All-In-One InkJet Printer
How To Resset brother printer dcp-150c
Resetting Brother DCP-150C Wastepad Counter
Unable to Clean error means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Unplug Printer, Press Menu Button until Maintenance Mode Appear.
2. Using arrow up button look for the following:
a. 8 then press SET/OK
b. 0 then press SET/OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET/OK
b. 7 then press SET/OK
b. 3 then press SET/OK
This is to reset the purge counter.
When “PURGE 00000” appear press STOP/EXIT
5. Using arrow up button look for the following:
a. 0 then press SET/OK
b. 1 then press SET/OK (To reset unit)
a. 9 then press SET/OK
b. 9 then press SET/OK (To exit Maintenance mode)
May 24, 2010 | Computers & Internet
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
