What is the possible solution in init unable 30 problem maintenace appeared in my printer message
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
  • 5 Answers
SOURCE: scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
Posted on May 15, 2009
  • 37 Answers
SOURCE: brother mfc465-cn unable to init 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
Posted on Jun 17, 2009
ITTech7574
  • 85 Answers
SOURCE: init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
Posted on Aug 31, 2009
Init unable 34 message
Printhead not moving. Check for any thing blocking the head or anything stuck.
Apr 10, 2014 | Brother DCP-J140w Compact Color Inkjet...
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Unable init 4f
the dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me
Jun 22, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
"unable to init" message appears on my MFC 210c
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Feb 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
Init unable 4f
Aug 31, 2009 | Brother DCP 130C All-In-One InkJet Printer
Scanner bar will not reset, error "unable to Init. AF"
May 10, 2009 | Office Equipment & Supplies
Unable to init appear on the lcd screen. after i replace the black ink. what should i do?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000002258&Sympt=How+do+I+clear+the+message+Please+Wait+%E2%80%93+Unable+to+Initialize+from+my+Brother+machine%E2%80%99s+display%3f+(pls%2c+init)&Model=22&ProductGroup=5&Keyword=unable%20to%20init&ProductID=DCP110C
Mar 28, 2009 | Brother DCP 115C All-In-One InkJet Printer
Dear Guru,
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-620CN
sure..you can go through this link, and enter model number, then ask for user manual.
Mar 10, 2008 | Brother MFC-620CN All-In-One InkJet...
jasbo
jasbo
