Question about Canon Office Equipment & Supplies
How do i fix front or left door open problem?
My canon ir 2018 keeps showing me "front or left door open" even though,the doors are closed
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
Posted on Jul 10, 2008
Harleyknut
  • 83 Answers
SOURCE: Reg door will not close
There is a flap inside the printer that guides the paper as it travels thru the printer. The flap has to be in a completely up position before the door can be closed. Problem is if you put the flap in the up position and then try to close the door the flap falls back down and blocks the door. You need to push the flap up and close the door quickly before it has time to fall back down.
Posted on Apr 02, 2009
  • 4 Answers
SOURCE: Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
Posted on Apr 30, 2009
iservice
  • 318 Answers
SOURCE: where is the waste cartridge for the canon ir 2018
If you open the front cover and release the leaver of the drum unit.Remove the drum unit.On the drum itself is a plastic plug,remove the plastic plug and remove the waste toner in to a bin.The waste toner is stored behind the drum and must be removed reguarly.
Posted on Dec 15, 2009
Kevin Hayes
  • 167 Answers
SOURCE: error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
Posted on Jan 06, 2010
Canon ir 2016 toner bag full
I'm assuming it is the waste toner full message. Power down copier- Main Power. Open front door and gray handle to open left side door and pull out drum. On the top there should be an opaque disk to be removed and then you can dump the waste toner into the trash. BE VERY CAREFUL THIS COULD GET MESSY.! Slide the drum back back into position, close the left door and front door. Power up the copier and all should be good.
Mar 13, 2017 | Canon iR 2016i Black and White Copier
Replaced rollers on dryer put back together door closed but keep getting message that it is not closed and wont run?
In order to replace the rollers you had to take off the dryer front. You probably had to unplug the wires to the door switch which if I remember right is in the top left corner of the front panel. Check those connections to the push button switch. If it is not connected, the door will show as open even though it is closed. Or the switch got damaged and is not making contact inside when door is closed. If i remember it is a 3 wire 1 piece plug.It also operates the drum light.
Mar 06, 2015 | GE Profile Harmony DPGT750EC Electric...
System error 007 for canon ir 2018
this is error for fixing film rotation. There is no reset code, you need to replace fixing film in fixing unit, Fixing unit is located under left sideway door above drum unit ( green roller ).
Call service!
Aug 26, 2011 | Canon iR 2016i Black and White Copier
I have been using Canon IR 2018, it shows an error message "System error e007" while copying or printing though its good with scanning.....kindly suggest me some proper remedy to come over....
there is a one white patch sensor on the fixing film, if this patch sensonsor can't read by fixing unit. machines will show E007 error because of fixing film broken.
so you requie to replace fixing film.
May 10, 2011 | Canon iR 2016i Black and White Copier
Waste toner full..
Open the front door and the left door.At thefront door were you remove the toner,next to the toner there is a blue lever.Release the leaver and remove the drum unit.On the drum unit there is a plastic plug remove the plug and though all toner in the dusbin.Do not use this toner again.
Feb 17, 2010 | Canon imageRUNNER 2018 Copier
Where is the waste cartridge for the canon ir 2018
Dec 14, 2009 | Canon imageRUNNER 2018 Copier
CANON IR-1210 IN THE DISPLAY IS STANDING: CONTR. TONER/DRUM HOW CAN I FIXED THAT? JOHAN THE NETHERLANDS
try to open the front door were you put the toner and close.if still showing the message replace he drum.
Oct 21, 2009 | Canon imageRUNNER 1210 Copier
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
old marine
old marine
