Question about Refrigerators
Bottom of freezer icing up - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Posted on Apr 04, 2015
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
