Question about Garden
Why do my tractor struggle to start when hot. Can my fuel pump be a tooth out
    Sergeant:
  • 462 Answers
Fuel purculating try to move fuel lines away from manifolds or exhaust
Posted on Apr 23, 2015
Diesel wont start hot
Could be the timing is off. Jumped a tooth, or recently had timing belt replaced incorrectly?
You might also have air in your fuel system - do you have a clear section of line that you can visually confirm fuel going to the injector pump? A blocked fuel filter could be causing a fuel vacuum back towards the tank.
Nov 10, 2013 | Cars & Trucks
Idling bad when car is hot.polo classic.2001
Tell me what engine you have, petrol or diesel
here is some things you can take a look at
Elect Connections
air in fuel
fuel non return valve
condition of fuel
air filter blockage
engine mechanical condition
fuel injectors pump timing
engine coolant temp sensor
fuel quantity adjuster / positioning sensor
injector pump
fuel pump
ecm faults
Mar 05, 2013 | Ford Explorer Sport Cars & Trucks
Why does the engine quit running after it gets hot?
You might want to try this one but pricey thing, replace the carburetor! I have a 2008 Sears DTY 3000 25 HP two cylinder Briggs and Stratton Engine, I struggled for a year and half if it quitting when it gets hot. I replaced everything, Gas Cap, ignition module, fuel lines , filters , spark plugs, gas tank, exhaust / exhaust manifold and it all did not help. Due to the acidic (Alcohol added to the fuel) gas two the rubber inner control gaskets disintegrated causing "vapor lock" when the engine got warm/hot. Replace the Carb and then put additive into the fuel.
Oct 13, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My fiat uno 1993 model,Cuts out and struggles to get petrol through,I have replaced the feul filter.
Just check,
  • fuel pipe
  • fuel pump ,fuses, wiring
  • if mpfi engine, check the injectors.
  • spray some fuel line cleaners into fuel line, pcv, air filter
  • pls vote!!
Sep 24, 2011 | Fiat 500 Cars & Trucks
I have a john deere 6400 that wont start from cold even with a new battery it needs jump leads from another tractor and then still struggles the hazard warning light and the information light on the dash...
i had the same problem, it is most likely that your fuel lines are leaking and fuel pump in tank is weak
when the tractor sits for a while the fuel drains back into the tank, thus your injection pump has no fuel in it.i solved it by replacing all the lines and i added electric fuel pump on outside of tank and connected the power to key,when i start the tractor i turn key on for a minuet or so than start the engine ,it solved the problem.
john b
Nov 16, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Engine runs fine til hot.
I think one of the intake valves, or a valve pushrod, is bent or warped. When the engine heats up, the metal expands and the valve starts sticking open. That would cause compression to be lost in one cylinder, reducing available power so things drag when you engage the blades. This would also causes air/fuel to be blown back through the intake. I think you'll need to take it to a small engine mechanic. Good luck! Please rate my solution if helpful, thanks.
Jul 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
