I need to fix a new front felt drum seal. How do I remove the front panel to do this. Have the seal already just don't know how to do it
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Its done from back
Posted on Apr 13, 2015
New Drum Install - Rubbing
Ken, Don't know if this will be of any help or not, as I've never seen a dryer drum with the felt seal on the front. All of the machines I've repaired, (and that's a bunch), had the felt seal on the rear of the drum, with the front being supported by the configuration of the front panel where the door is located. Mostly the front of the drums were supported by small strips of teflon, or cork, as slides, but that's it. Never had one with felt in front. Is it possible the drum is in backwards?
May 17, 2014 | LG DLE5977 Electric Dryer
Aeg lavatherm 33600
just remove the door front panel....the replacement felt is self sticking..........fix the felt with the join at the top...........
cheers
Jul 30, 2017 | Frigidaire GLEQ2152ES Electric Dryer
We have a problem with our frigidaire dryer FEQB4000FS0 snaps, zippers and buttons are getting caught in the gap between ther inside of the dryer and the drum, as a result all the clothes are getting...
Sounds like the felt seal is missing,shifted, or broken.
The felt seal is what keeps the zippers,buttons,etc from catching in the door and causing problems.
If you plan to do the repairs yourself, then make sure you unplug the dryer before starting any repairs.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum and felt seal.
You can now inspect the seal to see if it is faulty. Replace it if it is needed.
If you remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
I bought a used dryer (model # fde336res2, serial # xd01501804)The dryer works, needs a knob but it also eats my clothes. It seems to be a problem between the barrel and the front panel. The clothes get...
Your problem could be caused by a bad felt seal..the drum rotates against this seal. The purpose of the seal is to seal the hot air from going out of the drum and into the room.
Remove the front of the dryer and this should expose the drum and felt seal.
Sep 25, 2009 | Frigidaire Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The drum will not turn when you start the dryer. The belt will need to be exchanged but how can I access the belt?
You have to open the cabinet and remove the front. Some have screws through the front, others have the screws on the inside that are accessed after raising the lid. To open the top slide a thin flat blade under the front of the lid and feel for the two clips several inches in from the corners. Push straight in on a clip while pulling up on the lid at the front edge and it will release the lid at that point. Do the other clip. Lift the lid. If you don’t see the screws on the outside, they on each side on the inside holding the front tight. With the screws removed, pry out by each of the push clips on the side. The front should be come loose. Swing it away slightly paying attention to the wires to the door switch. Slide the new belt over the drum and work it to where it ran in the past. Put the front back on and snap the lid down. When putting the front on guide the front panel and the drum together at the felt seal. Open the panel on the back near the motor. Reach in and spring the belt tightener over and put the belt around the motor pulley. Let the spring tightener tighten the belt. Put the cover back on. If there isn’t an opening on the back to access the motor pulley, you have to reach under the drum from the front to thread the belt onto the motor pulley. When putting the front panel back on you need to guide the drum and the front panel together at the felt seal around the door opening. Vacuum the cabinet well while it is open and make certain to unplug the power cord and turn the gas off if applicable.
Jun 07, 2009 | LG DLG3788W Gas Dryer
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Hot point dryer
the drum has dropped
the drum is suspended on felt pads to seal the drum edges, nylon guides at the front, and rubber tyred thrust rollers to withstand the torque of the motor and belt at the rear.
the usual cause is the rollers have failed, common fault, easy fix, cheap too
good rollers look like this
1ac2db2.jpg worn rollers like this
try not to run the dryer till the rollers are replaced, the extra strain will break the belt,
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. pull tensioner fully agains spring
  3. remove belt from motor pulley
  4. lift drum and withdraw fully forwards
  5. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear
reassemble.
  1. loop belt loosely around drum at wear marks from prior installation
  2. reinsert drum onto rollers bearings slides felts as installed.
  3. loop belt around motor pulley
  4. pull tensioner pulley against spring to end of its travel
  5. loop belt around tensioner pulley
  6. relax tensioner pulley to tighten belt
  7. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Jun 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
