Replaced lid switch, water level sensor and timer. Machine fills and does nothing - no agitate / spin
  • Washing Mach... Master
  • 5,323 Answers
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Posted on Apr 13, 2015
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Hi. I have the Kenmore 110.92588210 washing machine. The machine will fill, agitate, drain and spin but will not refill again for the second rinse. It will actually skip the rinse and go right to...
Remove the tubing from the level switch and blow out any sediment that may be obstructing the tubing then re-secure. Yank out the timer molex plug and look for corrosion on the plug. Remove the timer. Remove the sheathing from the timer and turn the barrel with your finger looking for burnt spots on the barrel. That is a sign of arcing contacts. Replace the timer or send it off to be rebuilt if you see burnt spots. I gotta say from looking at this part and being a parts supplyer I never or rare ever sold any of these over the years, they simply don't go bad. Now if yours had a plastic housing yeppers I have sold many of them. Having seen the part I would say you have a bad timer. Try and clear the plastic tubing and make sure it ain't pinched up against the rear of the cabinet where the case fits against the bulkhead. It is supposed to be in the channel alongside the harness. Let me know.
Jul 04, 2011 | Kenmore 15944 Top Load Washer
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    The water comes out in the detergent/softerner liquid dispenser; instead in the main washer.
    Water Problems
    Sometimes water will not enter the machine in order to properly wash clothing. In that case, the water may be turned off or the water fill valve, water temperature switch or timer may not be functioning correctly. A defective water valve or timer can also cause the machine to not enter the spray rinse cycle. Another issue that arises is when the water will not drain out of the machine. The drain may simply be clogged, or the drain hose or pump may be malfunctioning. Water will splash on the floor if the pump or water valve is not working, or if the machine is operating on a low level of water with a high level of agitation, which means the force that promotes all the functions of the machine.
    Cycle Problems
    Malfunctions of the various cycles are common as well. If no agitation occurs, the agitator spine may be stripped, or the motor or internal transmission system could be broken. If the machine will neither agitate nor spin, the belt or coupling is most likely the problem. There are a number of issues associated with either no spin or a slow spin including an open lid, defective lid switch, spin tube, wigwag, timer or wigwag wire or a drive belt that is not properly adjusted. When the motor will not run at all, first check the power cord to make sure that it is plugged in. If that does not solve the problem, issues are found in the timer, lid switch, motor or water level switch.
    Other Issues
    Sometimes washing machines will excessively vibrate or "walk," meaning that they begin to inch forward while the motor is running. Check inside the machine to see if there is an unbalanced load. Heavier items, such as sneakers, cause vibration as well. The load can be fixed and any unnecessary items removed. If the problem persists, other possible issues include an improperly leveled machine, a worn-out snubber, broken suspension springs or shipping pins that have not been removed. Another problem that arises with washing machines is oil leakage caused by transmission failure, which is one of the more costly issues to fix.
    Cycle Problems
    Other Issues
    Mar 12, 2011 | Washing Machines
    Kenmore 80 series washing machine will fill up with water, then nothing happens
    Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
    Mar 18, 2010 | Washing Machines
    Washing machine fills, but will not agitate, drain or spin
    Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
    Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Kenmore 80 series won't agitate
    You will need to check you water level switch. Sound like it is bad or has something clogging it. You can test it like this. Find the tube that runs from the back of the level switch down to the outer tub. Unplug it from the tub. Now turn machine on so that it will start to fill. Now blow pressure into the tube. If it does not cut the water off, you have a bad switch. I would think it's bad. I see them about 5 ir 6 times a week.
    Please rate solution if helpful.
    Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Washing Machines Logo
    74 people viewed this question
    Top Washing Machines Experts
