Question about Photography
Why wont my jam rewind speaker turn on? - Photography
    Top Expert:
  • 14,162 Answers
Posted on May 25, 2016
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
Can I pair my jam wireless speaker with my IPod Nano 7th generation?
no because the speaker wont connect or show on any ipods except forr the ipod touch
Feb 17, 2015 | Hmdx Jam Plus Wireless Speaker for Most...
My jam classic wont go into pairing mode at all and my phone wont pick upat all
Make sure your Bluetooth is turned on on your phone. You may have to make it discoverable as well
Feb 09, 2015 | HMDX Audio JAM Bluetooth Wireless Speaker...
Starter cord has jammed
You will have to remove the starter rewind mechanism and rewind the cord around the pulley, then pre- load a certain amount of tension on the rewind spring.
Apr 17, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Rewind on my camera wont turn
Has the rewind knob become unscrewed or just won't turn? It does have to be turned clock-wise to rewind the film. If you would happen to turn it counter-clockwise, it would either jam or the knob itself would become undone from the rewind shaft.
Dec 25, 2007 | Photography
Photography Logo
325 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
