Ray,
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
There is an internal fuse.
Hi John. Many thanks for your reply which was very helpful. I found the fuse and replaced like for like but on testing it blew straight away. There is obviously a fault somewhere!! Any suggestions as to my next move? Regards Ray Newman
With it blowing right away, I would guess that you probably have a short in one of the door switches. There are usually 3 or 4 of those switches and it could be either one. If you have a multi-meter you can check them to see which one is bad. Good luck!
