Question about Crafts & Hobbies
Trying to change blades. lost manual - Crafts & Hobbies
    Top Expert:
  • 11,573 Answers
Ben, how to change blades. RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Aug 24, 2016
The manual start rope will not pull. Seems to be stuck.mower has been garage kept,no gas left in mower over the winter. Air filter and oil has been changed. Lost!!
Possible that the motor has frozen. See if blade can be manually turned after disconnecting the spark plug;using a long breaker bar, turn the bolt on the blade to see if you can unfreeze it if blade is stuck.. Make sure that you have oil in the crankcase.
Mar 29, 2017 | Garden
I need a manual for CJ500 jig saw. I can't work out how to change the blade.
Ryobi has a customer support questionnaire that you can fill in to ask a question http://ryobi.custhelp.com/app/support/ask/incidents.c$enquiry_type/11
I suggest that because their database of instruction manuals seems to be having problems. I did find a picture of one of those saws and it appears that there are 2 hex screws that hold the blade in. it's the hex caps in FRONT of the top of the blade. Loosen those hex cap screws and the old blade should fall out.
Jan 16, 2015 | Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Change blade without hitachi wrench
Which way do i turn the nut on the saw blade to change my blade? to me or away from me? looking at it from the front.
Mar 03, 2013 | Hitachi C10FR 10" Job-Site Table Saw 15...
How do I change my blade? I lost the manual. it has a guard and when I try to loosen nut it cant come all the way out cause the guard is there
Generally, depending on the manufacturer, the nut only has to be loosened and then looking from the blade end you will see a slotted screw. Turn the screw counterclockwise while wiggling the chain bar until the blade is loose enough to remove from the guides. You may have to put a small flat screwdriver under the retaining nut and pry up lightly while loosening the nuit with a wrench or socket..After backing the nut off enough the blade bar should slip up and away from the drive gear.
Apr 03, 2011 | Garden
Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Lost manual. cant take the blades off and put on
use a block of wood in the discharge chute to keep the blades from turning, loosen them all before you take the blocked blade completly off
Mar 17, 2009 | Garden
Crafts & Hobbies Logo
613 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
