Question about Saws
I require a new replacement motor for my Rexon mitre saw model SM2150AE.
  • Saws Master
  • 1,896 Answers
Also check the bearings when you are replacing the anchor and you want to do well even replace the drive gear and the motor brushes and replace the lubricant
Sm2150ae Armature assy SM2150AE 2BMY Availability In stock 31 99 inc Vat
Posted on Apr 02, 2016
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: Compound mitre saw won't shut off unlss unplugged
Relace the switch.
I am presuming the lock button has not been inadvertently pressed ... Check that first.
The condition you deacrive is dangerous. Please fix it before you use it any more.
If you require additional assistance, let me know.
Otherwise, check RepairClonic.com for parts and technnical instruction from their crack crew.
Thanks for the opportunity to lend you a hand
a
Posted on Sep 26, 2009
  • 12 Answers
SOURCE: Mastercraft Maximum Compound Mitre Saw
Mastercraft's help line is 1-800-689-9928. However this saw is no longer in production and parts are available only until stock is depleted. It was supplied by an european company called WMH Tool Group that apparently doesn't supply CTC any longer.
Posted on Aug 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Posted on Mar 01, 2012
How do I properly install the saw blade in the Rexon 15" Scroll Saw. I do not have a manual?
I'm not familiar with the saw. I suggest you to contact the manufacturer of the saw. They can help you with that.
Sep 14, 2014 | Saws
I require total new motor housing with powercable for ryobi cms812 mitre saw
Go to eReplacementparts.com. Enter make and model number. They are the best.
Aug 19, 2014 | Saws
Mitre saw makes horrible noise
  • It sounds like the bearings in the motor are running dry and causing the noise. Possibly spray some wd40 in there but more than likely you will need a new saw. Is it still under warranty? If so take advantage of your warrant.
Jul 05, 2014 | Dewalt Mitre Saw Workstation
Rexon 406mm Scroll Saw SS16SA
Submit your mnual request directly to Rexon.
Jun 17, 2014 | Saws
Searching for trunion table mounts for Rexon MBS 380S Bandsaw
I can't find any good supplier. I checked on the site ( bandsawparts.com) where I lastly purchased guides but they don't have parts for Rexon band saw . Try calling Rexon 01709 876611 . Hope that helps!
Aug 08, 2013 | Saws
Rexon tablesaw
Update on me trying to find a manual for the REXON TMS-10A saw:
I found a helpline sticker on the underside, a spares company based in south Yorkshire , UK, with a telephone number.which I called. They fixed me up with an emailed manual within seconds. Brilliant!
Here's the full contact details:
Rexonspares ltd
Unit 3,century park
Dearne lane
Manvers
Rotherham
South yorkshire
S63 5de
Tel: 01709-876611
Fax: 01709-876811
Web: www.rexonspares.co.uk
Jul 28, 2013 | Saws
Macallister mitre saw sparking
Feb 26, 2012 | Saws
Trying to locate downloadable operator manual for rexon scroll saw model # RM 411 maufactured in 1988
U.S.A.--POWER TOOL SPECIALISTS INC.
684 Huey Road Rock Hill, SC 29730 U.S.A.
Tel: 1-803-980-7740
Fax: 1-803-980-7750
Http://www.tradesman-rexon.com
E-mail: custserv@tradesman-rexon.com
I'm sorry I could not find any downloadable information on this scroll saw, but I would imagine if you call or email the company above, they may be able to email you a PDF of what you need. Good luck.
Nov 21, 2010 | Garden
Motor replacement for Bosch Mitre saw
Most often the entire motor doesn't go bad. It would be a componen't like armature, field, brushes, Switch. I very seldomly see a whole motor go bad. look for a single problem. The saw is not junk it is very repairable with some testing of parts.
Jul 12, 2010 | Bosch 10" Slide Miter Saw
Saws Logo
333 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
