Question about Huawei Cell Phones
My Huawei m835 smart phone won't charge, I plug in charger and it says its charging but it won't gain any battery. I tested charger and various USB cables its not the charger.
jessee007
  • 310 Answers
SOURCE: my razor has screen that says boot loader and cannot charge battery
try windows media player 11
Posted on Jan 04, 2008
ahlrub
  • 283 Answers
SOURCE: V3 not charging
it's a hardware failure,, cant fix it here ..
Posted on Apr 16, 2008
SOURCE: cect i9 wont charge battery is fine
The I9 battery charger is th problem. There is a small tab on the bottom edge of the batery that allow it to clip in the phone. This tab prevents the battery from going all the way into the charger which causes a missalignment with the contacts and due to the contacts being very thin they tend to break off. If this happens you must use the USB cable to charge the phone, it plugs in under the charger. If your contacts are good you can take a thin knife and ease the tab over the edge of the plastic lip on the charger alowing the battery to seat correctly in the charger making the proper connection.
Posted on Feb 25, 2009
misskittyfoo
  • 20 Answers
SOURCE: Charging battery of a Samsung U600 phone
I charge my phone (which is a Motorola) all the time with the USB cord. If you have the driver for your phone installed on your computer, it should work =)
Posted on May 28, 2009
  • 6 Answers
SOURCE: my n97 is not charging
It sounds like the charger is the problem. The battery and the phone seem to be ok since you can use the usb cable to charge the phone. I would check the charger to see if there is any visible damage. You can also see if a friend has the same connector (many new phones should due to the EU ruling last year) and check their charger with your phone and their phone with your charger to verify the charger is faulty, but replacing the charger would probably the best solution. Depending on how long you have had the phone, Nokia might cover the charger under the warranty, but I don't seem to be able to find that information.
Posted on Dec 03, 2010
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
My Huawei U8730 phone
charger isn't charging enough
Jul 16, 2015 | Huawei T-Mobile myTouch Q - Black
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
Apr 29, 2015 | Huawei Cell Phones
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
How to repair the charger port on a huawei m835 android
replace the motherboard thats the only way you can repair the charging port. its attached on to it not as a removable piece.
Nov 25, 2012 | Huawei Metro PCS M835 Android CDMA Video...
Just charged my new phone but it shuts off and won't work when I unplug charger
Are you shure your charger is working properly? Or that the battery is not shot?
Oct 21, 2012 | Huawei Cell Phones
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Huawei Impulse 4G
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Cell Phones Logo
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
William Alequin
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
