Question about Maxell Usb Hub Multiple Card Reader Combo Dual Usb Ports Store Away Usb Cord
Where do the four wires,ie.red,black,white and green go on the card reader
How to connect memory card reader on the motherboard in a targa now 8821. The connectors are all single or double how to mount.
if it is an USB card reader you should attach the pins to the usb header on the motherboard.
Not sure about USB3 devices but the wires should be RED/WHITE/GREEN/BLACK on USB 1 AND 2DEVICES.
If the motherboard header consists of two rows of pins, a row of four next a row of five pins then the red wire will go on the pin furthest away from the odd pin, I mean the extra one that is alone. Next to the red wire goes the white one then the green wire is next. The black wire will go on the pin directly next to the single pin, that is the earth wire.
Feb 07, 2015 | Computers & Internet
Need help with the green wire ground and white wire neutral
as long as the GREEN wires connected to the dryers metallic case your fine
Mar 08, 2012 | Frigidaire Dryers
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
MSI MOTHERBOARD - MS-6741 Ver:1 I have installed a 5 in 1 reader
yoyo
on the usb header on your motherboard 1 will have four pins and the lower row will have 5 or the other way around.......
the usb wires go as follows
red, white, green and black
top row left is red then white then green then the black this goes for the bottom row also is your card reader has to usb leads....
hope this helps
Rik
Jan 29, 2009 | MSI K8MM-ILSR Motherboard
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Mitsumi FA4o4M Combo Floppy Card and Data card reader/writer
black cable to be connected on a free usb outlet on the motherboard
Feb 02, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
Maxell Usb Hub Multiple Card Reader Combo Dual Usb Ports Store Away Usb Cord Logo
111 people viewed this question
Top Maxell Cameras Experts
Steve
Are you a Maxell Camera Expert? Answer questions, earn points and help others
