Question about LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive
How do i convert FAT 32 to NTFS without formatting / Loosing Files in my Hard Disk Drive?
    Master:
  • 294 Answers
1) Backup your data!
2) XP or later: Open CMD (DOS Window) "Convert" [Drive:] /fs:ntfs
To verify you have the command available, in Cmd window, type "convert /?" that should bring up the various parameters to use with the command. If convert is not available, it will return "unrecognized command".
Posted on Apr 03, 2015
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Hi, I have an iomega Prestige 2tb desktop hard drive which i was using on a PC but now want to use it for my macbook pro. How do i reformat the hard drive for Mac? Thankyou
Connect it to your Mac and open Disk Utility. Find the disk in the left pane of the Disk Utility window, click on it, then click the Erase tab in the right pane. Choose your format, then click the Erase button. If the disk does not appear in the left pane or is grayed out, click the Erase or Partition tab first, then select the disk.
Note: the "MS-DOS" format is the FAT-32 filing system. You will have to partition the volume (Partition tab) to use it since FAT-32 cannot cover the entire drive in one partition (I think it is limited to 80 GB). Microsoft won't let Apple use an NTFS volume for Write operations, but FAT-32 can be read and written by both Mac and Windows systems. If you think you may want to use the drive to share files with the PC, make two partitions - one formatted as Mac OS Extended (Journaled) and a smaller one formatted as FAT-32.
Jan 06, 2011 | Iomega 2TB Prestige External Hard Drive
I have Lacie Rikiki Go 500GB, when the first format I set it with Mac user. Now I want to use for both Mac/Window. Pls advise. Thanks
the easiest way to allow you to share data from the same partition between MAC and PC is to format your drive as MS-DOS (FAT 32) with Disk Utility, but you will be limited to files of 4GB or smaller.
Another way to do it is to format your drive as NTFS with Windows disk manager and to install an add on on your MAC that allows you to write to NTFS partitions (without add on, you will only be able to read NTFS partitions)
Regards,
Jan 05, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Conversion of file system
The conversion is actually necessary if you are going to use this device with Windows 7. Windows 7 will not read a FAT32 partition. All drives can be converted to NTFS, just remember the conversion is one way. It cannot be changed back without a complete format.
Jun 24, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
May 27, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Installing xp
always use NTFS - NTFS is the standard file system of Windows NT, including its later versions Windows 2000, Windows XP, Windows Server 2003, Windows Server 2008
Sep 10, 2009 | Microsoft Windows XP Professional for PC
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive Logo
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
