Question about Dell (E210882) Motherboard
Dell 4600 During a thunderstorm Lightning took out my DSL box.My pc won`t power on.I have a green light on the board working,and both fans,and the hd act light is on.Do you think that my board is shot?If not what else?
  • 59 Answers
We need to know exactly what the problem is. check on the back of the computer. right above the ports where you plugin a PS/2 mouse there are 4 led lights there. if the last combination it will give are all green then this is a video problem. the lights on the back are actually diagnostic led lights. it would help us a lot to figure out whats wrong with the computer using the combination of those lights. however, if the capslock key doesnt respond at all when pressed that it could be the mobo.
please let me know if you have any other questions
Posted on Nov 14, 2007
Polaroid FLM-3701 power
Unfortunately modern televisions and monitors are full of electronic semiconductors of which many are likely have got destroyed along with your original power supply during the storm. A nearby lightning strike will send high voltage spikes down aerial cables as well as through socket outlets.
If you have contents insurance you should be able to claim for a new monitor.
Nov 09, 2013 | Polaroid FLM-3701 Television
Dell 4600 won't power up following lightning storm. PSU and power button both test OK. Suggestions please! many thanks
Check everything between the power supply and the wall outlet. If everything else is working using the same power a part of your computer is fried.
Jul 27, 2011 | Dell Dimension 4600 PC Desktop
Dell dimension 4600c won't turn on since we had a power outage
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Sep 01, 2009 | Whirlpool AKZ159IX Oven
Power supply or motherboard dell 4600
Ok, you stated that the power supply cooling fan was running at this time. unfortunately, this is not the power supply unit that has failed. the mother board has actually failed in this case. If the power unit was damaged, the cooling fan would not spin. You will need tp replace the mother board in this case. it has failed.
This is not a novice situation. we recommend a service tech for this type of repair. if it was a power supply issue, it would have been quite easy to replace but, this is not the issue here. it the mother board.
Jun 22, 2009 | Dell Dimension 4600 PC Desktop
Have a dell dimension 4600. I have a blinking
The two biggest culprits would be:
the power supply and the motherboard.
I'd start with the power supply since it's cheap and easy to install.
Find a local computer shop that sells 'em.
Make sure they've got a 100% return policy.
Swap 'em, if it works problem solved.
If not it's probably the motherboard. You could always have a local tech check it out.
Make sure they provide FREE diagnostics. It shouldn't cost you anything to have ti looked at.
Jun 19, 2009 | Dell Dimension 4600 PC Desktop
Remote fans quit working during a thunderstorm-lots of lightning
I've been having the same problem with my remote not working. I actually just checked the dipswitches in the remote against the ones in the ceiling fan, and they somehow were not the same. It seems that the 4th dipswitch may have inadvertently been altered due to the battery either being changed or just moving. I advise you all check out the settings on the actual fan to see whether or not they match up.
Twist the cap covering the wiring above the fan (make sure the power is off, just in case), and you will see a black box like thing straddled towards the top. There is a little rubber square cap guarding the dipswitches. Take that off and note the setting of the 4 switches (on/off). Compare it with the remote by taking the batter pack off and looking at the 4 switches there.
I noticed that the 4th switch on my remote was turned on when it should have been off. I changed it back, and now it works.
Hopefully this helps you all.
Jun 15, 2009 | Dryers
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Dell (E210882) Motherboard Logo
100 people viewed this question
Alun Cox
