Question about Bosch Classixx WFL 2066 Front Load Washer
Leaks left side underneath..only on rinse cycle
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 536 Answers
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Also check the drain hose and pump assembly for cracks and tears.
Posted on Apr 20, 2015
    Master:
  • Bosch Master
  • 487 Answers
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Posted on Apr 03, 2015
Why my Bravo MTW 6600 TBO leaking when on the rinse cycle?
Sounds like the hoses on the pump have perished or pump ps best way is do a cycle let it rinse then when you see it leaking turn power off , make the machine safe and lower it down where you can see underneath at the pump hoses
Dec 13, 2017 | Washing Machines
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
When water filling before cycle starts, leaking coming below top lid of overall machine on left side only. however, when testing using the rinse cycle, no leaking
I had this problem with my old Maytag (top-load) - it was the injector - an assembly mounted on the top left of the machine - a $10 fix (about $36 for the entire assembly) and the problem disappeared!_906.jpg
Jan 20, 2011 | Maytag LAT2600A Top Load Washer
Washing machine is leaking on wash/rinse cycle. Hoses and plumbing is fine.
Check the soap tray for cracks etc & the input from that to the outer drum. Also seal to door.
To isolate the leak look underneath- is it at the front or rear or side etc.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
My LG front loading wm1814cw washer is leaking from the front panel (not from the door but underneath the front panel). I have to say about half of the water from the load is in the drip pan at the end of...
On the bottom left side there is a cover cap open it up an there is a drain pump filter and a drain plug. plug may be lose. But clean the drain pump filter.an tighen the plug. if that dont work call 1-800-243-0000
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
122 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
