Question about Hotpoint Ultima WF860 Front Load Washer
Release child lock - Hotpoint Ultima WF860 Front Load Washer
    Master:
  • Hotpoint Master
  • 487 Answers
You can download the user manual at: http://www.hk-krasnodar.ru/?option=com_k2&view=itemlist&task=user&id=1389 Also you might try holding the child lock down for 10 or more seconds.
Posted on Apr 03, 2015
Testimonial: "Thanks very much. Was given the machine and no manual! Problem solved now! Thanks"
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
Non powered sliding doors will not open from inside....not a child lock issue
If, like on mine, the child safety lock on one side did not fully release due to a bit of a sloppy end on the activator. Had to reduce the slack a bit so the lock mechanism would fully clear.
Try this: Set the child lock to on...and then a 'fast flip to off' and see if it goes off on several tries.... mine did for a while...but reverted back to needing attention.
Apr 18, 2014 | Dodge 2007 Grand Caravan
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
I have a samsung hitron and tv as a child lock on and ca't get it off
Child Lock cannot be released using the buttons on the side...Only the remote control can release the Child Lock setting, so keep the remote control away from children...... Press the ▲ or ▼ button to select Child Lock, then press the ENTER button...... 4 Press the ▲ or ▼ button to select On...Press the ENTER button......
Aug 19, 2010 | Televison & Video
Child lock on my tv dont have original remote
Apex child lock release sequences AT3208 Push and hold the "F" button on the remote and press mute. Release then press 6688 PF2020 Push display for 10 seconds and enter 3308 GT2711 Enter the pass code of 1225 to clear
Apr 16, 2010 | Apex Digital GT2715DV 27 in. TV/DVD Combo
A child is on my magnavox tv
dear prettgirl,
Childlock is used to lock the buttons present in tv panel. you cannot use that buttons until you release that lock. and you can only release tat lock from your remote control.
Sep 06, 2008 | Philips Magnavox 27MS343S 27" TV
Renault Clio Rear Door Lock Fault
It has nothing to do with the "child lock" It is a know problem in this car, they tend to get caught in lock. Only thing to do, is to take of the panel then the outside handle, and through that hole destroy the plastic covering the lock, a large screwdriver and hammer will do! Then you can release the lock, while you pull the inside release handle. Buy new!
Jul 23, 2008 | Renault Clio Cars & Trucks
Hotpoint Ultima WF860 Front Load Washer Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
