Question about Yamaha Audio Players & Recorders
Why does my receiver have no power and can't turn on?
Hi, my Yamaha AV Receiver HTR-5940 (EU) stop working the second time. First time and now the second time the same thing, no power, can't turn the device on. First time the service told me that the power supply was burned and they have replaced it. I used the receiver 5 times and now it doesn't work again. Can some one help me fix it by my self please :) I have tried the following following the users manual: General TROUBLESHOOTING This unit fails to turn on or enters the standby mode soon after the power is turned on. The power cable is not connected or the plug is not completely inserted. Connect the power cable firmly. - The speaker impedance setting is incorrect. Set the speaker impedance to match your speakers. - The protection circuitry has been activated. Make sure that all speaker wire connections on this unit and on all speakers are secure and that the wire for each connection does not touch anything other than its respective connection. - This unit has been exposed to a strong external electric shock (such as lightning or strong static electricity). Set this unit to the standby mode, disconnect the power cable, plug it back in after 30 seconds and then use it normally.
    Genius:
  • Yamaha Master
  • 1,054 Answers
What exactly is the unit doing? Do you hear a relay click or anything when you press the power button?
Posted on Apr 03, 2015
Testimonial: "No relay click, just the button it self."
  • 1 more comment
  • Steve K Apr 03, 2015
    could be locked in protection mode. Try holding down the "INPUT MODE" and "MULTI CH INPUT" buttons and then press power. If it does turn on, make sure to look at the display when it first powers up. This will tell you what part of the protection circuit was triggered causing the unit to shut down.
  • Giuseppe
    Giuseppe Apr 03, 2015
    Didn't work, the receiver shows no life signs :(
  • Steve K Apr 04, 2015
    Sounds like it would need to be looked at directly by a pro. It could be either something in the standby power supply, or digital board. Hard to troubleshoot something like this via email.
    Master:
  • Yamaha Master
  • 487 Answers
Have you checked the internal fuses?
Testimonial: "I have not, how do i do that? I suppose that i need a multimeter?"
  • Giuseppe
    I know where they are, one is transparent the other is ceramic.
  • Giuseppe
    Giuseppe Apr 04, 2015
    Checked both of them, they are ok.
    Habit-Forming:
    New Friend:
  • 17 Answers
It is possible that the Standby/On switch contacts are intermittent. You might try spraying some contact cleaner on it. I use LPS Electro 140. It's not cheap, but it has solved quite a few problems, including noisy volume controls, relay contacts, and flashlight contacts. For best access you'll want to remove the cover and spray just area where the button shaft enters the switch body. First put a cloth around the around the switch to shield the surrounding areas. The power relay, mentioned by Steve K, is also a candidate for intermittent contacts. If the cover is removable, spray the contacts, using a shield as before. If the relay is the culprit, I recommend that you clean the contacts with a narrow strip of heavy paper (like from a business card). Be careful not to overstress the contacts by over-bending them. Start with a dry strip, then moisten another strip with a little LPS.
Electro 140 Cleaner Aerosol 11 oz
Posted on Apr 04, 2015
I have Yamaha HTR-5940. When I turn it on it's automatically turns itself off.
Shorted component/s at its power amplifier section circuit. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 11, 2015 | Yamaha HTR-6030 Receiver
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
Turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Jul 22, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Feb 21, 2008 | Yamaha HTR-5940 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
298 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
