Machine stuck on water ejection mode and will not accept water in to wash
  • Washing Mach... Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Posted on Apr 20, 2015
Why is radio stuck?
radio stuck in phone mode Cars & Trucks Questions ...
www.fixya.com > Forum > Tags > radio stuck in phone mode
Cars & Trucks radio stuck in phone mode questions and answers. Ask your radio stuck in phone mode car and truck question. Get free help, advice & support for ...
CD Player Stuck on Eject Mode & my Truck isn't ... - Car Talk
community.cartalk.com/.../cd-player-stuck-on-eject-mode-my-truck-isnt-...
Apr 28, 2009 - CD Player Stuck on Eject Mode & my Truck isn't Even On !! ... It won't accept a CD, but the stereo still works; however, the digital screen shows ...
Dec 29, 2015 | Cars & Trucks
Whirlpool wwdc 9940 , it's one in the 6th sense range. I believe my washing machine is stuck in demo mode and I cannot get it back to being usable. Help!! I have so much washing to do!
I don't believe there is a demo mode in a washing machine. You would either do a wash or not do a wash. The internet seems to know nothing about it either. Contact the dealer.
You do have the water switched on?
If you have used the machine normally before, you have a fault and need to call a repair man.
Aug 16, 2015 | Washing Machines
Why does my RCA VR667 not accept a tape and returns a eject or stop message?
A couple of reasons. First the carriage the tape sits in is damaged. Next the mechanism that moves the tape is damaged and can't except a tape. Lastly or perhaps due to the later, the mode switch is faulty or not in the right position. The mode switch tells the electronics which position the mechanism is in, be it play, fast forward or eject etc. If the switch is faulty and stuck in eject then it wont except a tape.
May 11, 2014 | RCA Televison & Video
Will not spin
Some of the Wash Progress LEDs flash when the machine stops due to a fault. The 8 Wash Progress LEDs stands for the binary digits and by indicating the digits, the fault code number is determined. The fault code can be shown by activating Diagnostic Mode if none of the Wash Progress LEDs are lit.
Turn machine OFF on the control panel then hold down the Water Temp Down button and press the POWER button until the machine gives 2 short beeps and lights up. Release buttons and you are in Diagnostic mode. Press the Spin Speed Up button 3 times until the Hold and Slow LEDs are lit. Write down the LEDs which are lit across the Wash Progress LEDs and post it back.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting the solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding your concern stated herein.
Sep 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stuck in fill mode
More likely the soleniod valve has dirt stuck undr the seat and it cannot close....
Kind of the opposite of this problem that I wrote about in these tips...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 16, 2010 | Washing Machines
I have a fisher & paykel IW810 washing machine that will not fill the bowl with water. While filling, it is also pumping the water out, in the autowater level sensing mode. I have gone into the command...
hi, reading your posting it tells me that the machine will fill on traditional wash but on auto fill mode it pumps the water out at the same time it is filling. i"m pretty sure it is your diverter . on auto fill mode it fills a little bit then the pump comes on and recirculates your water by pumping the water from the bottom of the bowl to the top of the bowl over the clothes. on auto fill mode it also activates the diverter to pump the water back to the bowl. on your machine the diverter is stuck in the drain out position so when it trys to recirculate the water it drains out the water instead . the problem could be a faulty diverter, control module or a broken wire.hope this helps, please reply if you need more help. good luck.
May 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Macbook cdrom stuck in copy mode
hold down power button until your machine shuts off. then power back on. you should be fine. if the cd is stuck in the drive, restart the machine and hold down the mouse button while restarting - the cd should eject itself.
Sep 02, 2008 | Apple MacBook PC Notebook
The system is stuck in mp3 mode and will not eject or accept a dvd.
i took it a part and sprayed some air on it then i put it back together and it worked not sure why though
Jul 23, 2008 | Philips HTS-6500/37 System
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
