Question about John Deere Garden
I have a john Deere 310sg backhoe that is showing a f-428 service code and also have an issue with the park brakes continuesly setting is this a simple fix. The computer was recently replaced
  • John Deere Master
  • 2,760 Answers
F-428 means the foot throttle pedal sensor is not calbrated
the software that's in the computer , this makes sense since u replaced the computer recently , to fix this its gonna require the JD tuning tool interface and software 4 it
I suspect the park brakes issue is sort of coming from a similar conflict in sensors on the transaxle or something
gone is the days that a new computer would self adjust its self when 1st installed , in fact if you read your owners book JD requires a yearly software update now
Posted on May 15, 2015
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 3320 starts up,engine runs,pto works
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Posted on Feb 17, 2010
SOURCE: Won't start John Deere 310D Rubber tire backhoe
wont go forward or back
Posted on Jun 24, 2010
SOURCE: LA150 john deere riding mower transmission slips
this transmission is a sealed unit, no way to add fluid or change filter.
Posted on Aug 12, 2010
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
LOCATION OF 310 SJ PARKING BRAKE SOLENOID
Back solenoid on top of transmission
Feb 05, 2014 | John Deere 310sj Backhoe
Park Brake circuit light on 310sj backhoe error light
Check the wire that installs into the sending unit from the origin (source). It could be pulled loose. If ok, there is a button type switch that disengages after the brake is released, this button switch could be faulty or otherwise dysfunctional.
Dec 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a 310SG john Deere backhoe and it loses power in 3rd and 4th gear on a hill I need help please.
I'm having the same problem with my jd 310. Did you ever end up finding a solution?
Dec 19, 2012 | Cars & Trucks
2003 John Deere 310SG Code F494
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 11, 2012 | John Deere Garden
If you can test the alternator after it has run for 2 hours that would be helpful,if it is quiting after it gets hot then it likely need the stator replaced in the alternator.If this is not the case,then you need to either replace the park lock solenod valve or the instrument cluster is overheating a transistor and failing,this will cause the safety interlock circut to engage.Also the operator pressence switch may need to be relocated if the operator is less then 150lbs.Let me know how you make out,thanks.
Apr 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
638 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
