Can you supply a front casing for this machine?
Mbriancarroll@hotmail.com
Both monitors work with indoor power supply but only one with car power supply
Your car power supply might not have enough juice to power both monitors at the same time.
Jul 23, 2014 | Case Logic 7" To 10" In Car Portable DVD...
Optoma DV10 stops after 2-4 minutes of work
2-5 minutes , it will not overheat
the power supply is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 19, 2014 | Optoma Office Equipment & Supplies
The tv is completely dead. i check the power supply everything checks out ok, there is only 2.5 volts coming out of the supply module. the input of the computer module has the same voltage 2.5...
there may be some bad capacitors in the primary of the power supply. do you get any led lights the front? most polaroids will have a red led on the front if the standby supply is good. there will most likely be some smaller caps 47mf@50v 10mf@50v probably that value that are bad.
Dec 17, 2010 | Polaroid Televison & Video
I need a recovery disc for an E-Machine that I bought in 2006.....SN XRC6880004243.......Model # e-machine T3516 I bought it at Best Buy in Tucson, AZ.....they said to contact you. Can you help...
I would contact E-Machines they supply two methods of contacting them.
First is there live chat which can be found here
http://www.emachines.com/corporate/contacts.html
Second is there email support which you can found there as well.
Most company's will supply restore cd's if you supply them with the registration number on the case.
Nov 04, 2010 | E-Machines eMachines Desktop PC
The top thread keeps breaking, I have tried with different threads and needles
hi htere
if ur machine is lockstitch try to use new bobin case or readjust the screw for spring. normally we change bobin case with new one also try to send ur machine model to any one can help u on site
best regards
ashraf abozid
aabozid@hotmail.com
Aug 16, 2010 | Sewing Machines
Drain line lg tromm
its a pretty complicated process to take off the front panel, you will need special tools for this problem, i would bring it to a professional, the easist way is to lay it on the back side and go from there, if not like stated above bring it to a pro.
ps:drain lines hardly go bad on LG's hmm,if it's leaking then it might be the internal supply lines on the top.
just a hint,
shoots dave
drsn777@hotmail.com
Jul 05, 2008 | LG WM2688HWM TROMM SteamWasher
Won't start
startlight blinking? any fault codes coming up,Possible door lock issue, i fthe machine doesnt think the door is closed it wont operate at all
Feb 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have server model compaq proliant ml 370
hdd controler dead or disabled fom bios in the luky case
Nov 11, 2007 | Compaq Refurbished PRLNT ML370 G2 POWER...
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
