My bizhub C235 does not want to start up properly.
When switched on my C235 does not respond correctly. The fan starts running and only the little green light on the main power is on and the light around the start button.
    Master:
  • 576 Answers
Hi Rudolf
There is a utility you can download that can help troubleshoot this...
http://www.biz.konicaminolta.com/download/
Posted on Sep 04, 2015
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
IB4G2008
  • 3587 Answers
SOURCE: pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Posted on Feb 15, 2008
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
ashish13
  • 75 Answers
SOURCE: My Dell 9100 desktop won't start.
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Posted on Feb 11, 2009
The fan turns on, blades don't move. The net says it is a bad motor capacitor. Mine has an LJY280A single capacitor switch. If I replace that, the fan should operate correctly, yes?
It probably is the capacitor but no guarantees as the insulation of the motor windings could have broken down or there might be another fault. Proper checking with an insulation tester is advisable.
If the capacitor is merely a start capacitor and not a start/run capacitor the motor should perhaps hum a little when switched on and then run normally if the fan blades are given a vigorous turn by hand.
There are several ways of arranging the motor circuit and some knowledge of these would be useful. You could have the capacitor tested by a local motor expert.
Capacitors bought as spare parts from appliance manufacturers tend to be very expensive. Capacitors are usually bought in by such manufacturers and replacements can be sourced much cheaper direct if the type and values and the maker's detail are present on the capacitor case, otherwise you will need the services of a motor specialist to determine the values for you if the information isn't available elsewhere.
Feb 17, 2017 | Hunter Dryers
MY BIZHUB 283 SHOWING THE ERROR CODE C-0202
Code
C0202
Description
Tray 1 feeder up/down abnormality
The tray 1 upper limit sensor (PS22) is not blocked even after the lapse of a given period of time after the lifting motion has been started.
Remedy
1 Check the connector between M12-PRCB CN25 for proper connection and correct as necessary. 2 Check the connector of M12 for proper drive coupling and correct as necessary. 3 Check the connector between PS25-relay CN30- PRCB CN26 for proper connection and correct as necessary. 4 PS25 I/O check, sensor check PRCB CN26-3 (ON). 5 M12 operation check PRCB CN25-5 (REM). 6 Replace M12. 7 PRCB ICP5 conduction check. 8 Replace PRCB.
Konica Minolta bizhub C224e Error Codes
Nov 08, 2016 | Office Equipment & Supplies
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
Erro 2351 da bizhub 164
C2351Suction fan motor malfunction
- The fan lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary.1 Check the connector between FM5-relay CN13-PRCB CN14 for proper connection and correct as necessary. 2 Check the fan for possible overload and correct as necessary. 3 FM5 operation check. 4 Change PRCB.
164
http://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20164&code=C2351
Sep 11, 2016 | Konica Minolta bizhub Office Equipment &...
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Oct 03, 2013 | Konica Minolta bizhub C250 All-In-One...
1998 Chevy Prizm A/C and Cooling Fan Problems
Compressor could not work without cooling fan comming on.
Check compressor mounting bolts and belt placement on pulley regarding the noise.
But before we get to the a/c system repairs its important to have a properly working cooling system.
Is the car overheating ? It should if neither fan works.
If I recall correctly the fan switch is usually on the upper radiator hose coupling.
you may want to test the fan(s) its self. Remove the electical connectors fron the fan(s) , fabricate a set of jumper wires and run it from the battery. If this works the fan(s) are ok . If it doesn't replace the ones that don't work.
The coolant switch aka fan switch is usually tested with an ohmmeter . Use shop manual for testing procedure.
Test the a/c fan and engine cooling fan relays. (see shop manual for details)
Then I would start looking at coolant( correct mixture and thermostat2_bing.gif) although the thermostat is not likely to cause this.
If all of this still doesn't correct the problem it may be the ECU that monitors this system it may not be responding to the signal /voltage from coolant temp sensor to turn on the fan, (again nedd shop manual to test this)
Once you have a properly working cooling systemnow you can turn your focus on the a/c. Compressors either work or they don't.For you safety I recommend having the a/c system serviced by a ASE certified Technician or a tech's who legally can perform a/c service. Good luck
Nov 27, 2009 | 1998 Chevrolet Prizm
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
