Question about Panasonic Audio Players & Recorders
My Panasonic Sa-bt235 won't play sons and I don't have the surround speakers I just want it hooked up to my t.v or what kinda speakers can I get from it?
devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
SOURCE: Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Posted on Aug 07, 2008
SOURCE: need to connect xbox 360 to panasonic sa-mt1
If you want to play 5.1 sound, and you got to need this fiber optic cable(black single cable)..with reciver decoder with optical on IN, to connect the xbox 360 machine on, and the high defintion cable of the xbox.
Posted on Feb 22, 2009
CW Oly
  • 240 Answers
SOURCE: How can I connect my Panasonic SA-HT540 to my PC
If your sound card supports 5.1 and your Panasonic supports 6 channel input then you should be able to do this with extra cables and changing some settings on your computer. Your sound card should have three "headphone" plugs on it. The cable you are currently using for front speakers is likely a 3.5mm to RCA cable. You will need two more of these. With these you will have your 6 channels, or, 5.1. All you do then is tell the sound card driver that this is how you want it to output and it will tell you which cable to hook where.
Otherwise, you have have a single coaxial digital out on your sound card and this is probably best.
Which you use should depend on which component has a higher quality DAC.
Posted on Jan 15, 2010
  • 447 Answers
SOURCE: Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Posted on Feb 03, 2010
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Panasonic SA-HT878 Home Theatre want the tv to play through the surround system no matter if tv on sat dvd wifi etc please help
if your tv has an optical audio output, then hook that up to the sound system. This will put all tv audio through there instead of the tv speakers. You may have to enable that audio jack in the tv's setup menu.
Apr 23, 2014 | Audio Players & Recorders
My Panasonic SA-PT875 surround sound system won't
Hi, I have the same issue ! ... Can you let me know if you fixed it please.
Regards Brad
Aug 16, 2011 | Panasonic Audio Players & Recorders
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
I hooked an HDMI cable from the receiver to the tv and am not getting sound. My surround sound speakers are not hooked up. Can I just get sound out of the tv? if so, how...?
http://www.retrevo.com/support/Panasonic-SA-XR55-Receivers-manual/id/391ci053/t/2/
Without knowing any details of your TV...
a) What's the receiver's role in your system if it has no speakers?
b) What source(s)?
Page 5 for basic audio.
Mar 29, 2011 | Panasonic SA-XR55 Receiver
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Certain dvds lose the surround sound
if you are playing older or burnt dvds then chances are they were recorded using only 2 channel or stereo instead of 5.1,6.1 or 7.1 hope this is your solution
Aug 05, 2009 | Panasonic Audio Players & Recorders
Panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Feb 26, 2009 | Panasonic Audio Players & Recorders
Aug 04, 2008 | Panasonic Home Theater System System
53 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
