When i turn the tv on i get the message do not power off-scanning
Scans over and over again.wont respond to remote or any side buttons.anyway to reset tv to factory settings?
    New Friend:
Try holding down the menu button on the lefthand side of the TV for 10 seconds.
Posted on Apr 03, 2015
Testimonial: "held down menu button but it carries on scanning?"
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Hi, i bought dish universal remote . all buttons working but volume buttons not so please help me. my old remote was 1.5ir and new has 3.2 ir universal
Hello, it sounds like all that you need to do is program your remote to the tv. Because I do not know the brand of your tv, I'll give you the power scan instructions. The power scan scans the tv for the correct remote code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Hope this helps!!
Becki Barned
DISH Network Customer Service
Feb 02, 2011 | DISH Network IR Remote Control
HAD REMOTE2 set to turn on/off LG TV. trying to reprogram and it wont take code nor scan to find. Sat works tv does not.
dmmcgregor
I'm sorry you are having problems reprogramming your TV 2 remote to your LG TV. Have you replaced your batteries? If so, I have provided a link on how to reprogram the remote and how to perform a power scan. I will also give you several codes that should work with the LG TV. This is the link with the instructions for programming the remote to your TV. It begins with step 6.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
If you have any other questions or problems, please respond to this site.
Ray Calo DISH Network
Jan 22, 2011 | DISH Network IR Remote Control
How do i program this remote to a mitsubishi tv?
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Oct 20, 2009 | Big Button TV Universal Remote
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
