Question about A4tech G7 Compact Wireless Desktop Gl-5300 ,kbdmouse
Lost my usb recevier for wifi keyboard and mouse, can i use a wifi receiver for other manufacturer?
  • A4tech Master
  • 5,631 Answers
Never tried it but I can't see any issue why not. Try it.
Posted on May 12, 2015
Cant find nano mouse receiver can i still use mouse without it
You will have to purchase a new receiver. There is no software solution for a lost mouse receiver I am afraid
Sep 11, 2014 | Gear Head Mp2325blk 2.4ghz Wireless...
Can I use another USB receiver from the same model (988614) with my keyboard and mouse?
You can try removing the batteries from the keyboard and mouse. Leave them out for ten minutes or so, and then replace them and try again. If they are the exact same components, it should work. The manufactures use what's know as "firmware" in the products. It's basically the same as software, but it's downloaded into the ICs,(electronics parts) with your keyboard and mouse. They new combination may not work because of differing firmware, but it's certainly worth a try.
Jun 10, 2014 | GE Wireless Office Keyboard/Mouse HO98055
No lights on keyboard
Several possibilities.
Your unit is wireless so the most likely is the USB Wifi receiver has lost connection. Unplug the USB receiver and plug it into a different USB port.
It is possible the unit battery has run down. Replace it with a fresh battery.
If your unit also has a wireless mouse with it and the mouse is still working, you may just have a faulty keyboard. It happens.
Nov 05, 2013 | Logitech 967437-0403 Keyboard
I've wireless hp mouse to which i lost tha recevier usb(dongle), but i got a dongle from another hp wireless mouse...cant get them to work as a pair though...hp wireless laser comfort mous P.N. XA965AA and...
I'm not sure can I help you, I had same issue with logitech, I couldn't solve issue, until I found program (app) that had option to connect them, search on hp for application.
Logitechs one is called SetPoint.
Sep 14, 2013 | HP Wireless Laser Comfort Mouse
My KB5500W Gearhead keyboard was just working, and now it has stopped. I have changed the batteries and plugged the USB 2.4GHz recevier into other USB ports, hit the "what the experts call" a...
Using another keyboard/mouse while in Windows, Go to Start, then right click My Computer and click Properties. Then goto Device Manager. Do you see any exclamation marks or question marks? If so, you may need a permanent driver and Windows is using a plug and play that is not working correctly or taking too long to load.
Mar 01, 2011 | Gear Head WIRELESS keyboard/Mouse
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
Key board help :{
The keyboard and the mouse work on different wireless sensors. Your wireless keyboard should have come with a receiver too. Unless the mouse and keyboard came together as a set, you'll need two different receivers. Check the battery compartment of the keyboard for the sensor. Some models have a hidden area there to store the usb key for the keyboard.
The only exception is if the keyboard is bluetooth, and your computer already has a bluetooth receiver in it (many laptops and phones come with this feature, lately). You will have to check the website for your keyboard's manufacturer to download drivers. You may also be able to order a replacement USB key for it, but I've never been able to. :P
Best bet is to contact the guy you bought the keyboard from and ask him/her: "Where's the USB receiver for this keyboard you sold me?"
Apr 23, 2010 | Logitech Wireless Access Duo Optical...
Lost the Mi mouce usb ir indicator
First, contact the manufacturer to verify with them if you can buy a separate USB IR dongle.
The USB dongle should work with your wireless mouse, though it's not the original receiver of it. They just need to detect each other and they will work together.
But if the manufacturer say that, you cannot buy a separate USB IR receiver, then you need to check the mouse itself and see if there's a USB port and check if it's capable of becoming a wired mouse.
If that's the case, you just need to buy a USB cable, then you can use your mouse as a wired mouse.
NOTE: Not all mice are capable of converting itself from wireless to wired. You just need to check your mouse. And that is only an option.
Feb 25, 2010 | Micro Innovations Wireless Optical Travel...
Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Feb 25, 2008 | Fellowes Manufacturing 99666...
Logitech v450 laser notebook mouse usb receiver
hi
you can always get a replacement from where you bought it. but i suggest if its still under warranty, have it replaced.
Jan 19, 2008 | Logitech Cordless Mouse
A4tech G7 Compact Wireless Desktop Gl-5300 ,kbdmouse Logo
143 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
