Question about Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive
Cyclic Redundancy Check error appears in wd element 1TB hard disk. how to repair to open it. It contains lots of data.
Successalways1992@gmail.com
  • 73 Answers
Opening the drive outside of a clean room (meaning a special room with no contaminants and air filtration) will allow the drive surface to be contaminated and cause more problems than you have. Best solution is a data recovery specialist and expected cost is in the $500 to several thousand dollar range.
Posted on Apr 04, 2015
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Hard disk cyclic redundancy check
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
My harddisk isnt opening and is asking me to" format the disk before use".when i cancel it says"G:is not accessible.Data error(cylic redundancy check) kindly help me retrieve my data.it...
When you try to write a block of data onto the disk-drive, a CRC (Cyclic Redundancy Check) value is calculated, based on the values of the bits of the data. Then, both your data and the CRC are written to the disk-drive. When you read that block of data, the CRC is also read from the disk, and the CRC is recalculated, based on the data that was read from the disk.
If the "new" CRC does not match the "old" CRC, then your block of data has been corrupted,
i.e,. the disk-drive is malfunctioning.
See: https://services.seagate.com/index.aspx?lng=en-US
for a professional "data recovery" service -- they will try to repair your disk-drive,
just long-enough to retrieve and copy all your files to a new disk-drive.
Nov 10, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
Western Digital Wd Elements Se 1tb Portable Black Wdbabv0010 USB 20 Hard Drive Logo
137 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
