Question about Ovens
Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
    Champion:
  • 220 Answers
No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
Posted on Apr 04, 2015
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: Stoves Newhome GL916
    The timer has broken and needs replacing
    I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
    Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
    Hope this helps
    Cost of timer from stoves £56.83 inc vat and delivery
    Posted on Jan 07, 2009
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    heatman101
    • 43501 Answers
    SOURCE: Top oven (and Grill) have stopped working
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Posted on Jul 30, 2010
    SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
    my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
    Posted on Aug 12, 2010
    Replaced EOU43002X element, clock/timer now dead
    Make sure there is power to the timer. Should be a fuse somewhere.
    Mar 19, 2014 | Electrolux Ovens
    Smeg SD012 top oven failed
    Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
    Jan 17, 2014 | Smeg Ovens
    Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
    Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
    I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
    If you need a new clock/timer they are around £80 from espares.
    Jan 03, 2011 | Stoves 720EF Electric Double Oven
    Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
    First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
    The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
    To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
    So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
    Best of luck
    Nov 23, 2010 | Stoves 720EF Electric Double Oven
    How do i work the grill?
    Nov 21, 2010 | Stoves 720EF Electric Double Oven
    We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
    If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
    You need to to get the clock working, or you will not be able to use the main oven
    Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
    Display went blank during the self cleaning cycle
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    uiitu
    Apr 29, 2009 | GE JTP28 Electric Double Oven
    Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
    Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    149 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
