The video is frequently replaced by blue screen. is the IC gone?
The mechanic is saying IC is to be replaced but I doubt that he may change original part so I m thinking to repair it myself
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 04, 2015
My LG flat screen has red and blue line
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Oct 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Jul 23, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
No signal to screen
no motherboard is not dead ...
in motherboard there will be one IC (integrated circuit)called as video adapter IC ..
this IC will be situated near the AGP port if your motherboard needs graphics card if your motherboard has onboard video then it will be there near by the PCI slots ...
if this IC is gone or burnt you will not get the signals to the monitor ...
and if you are using the graphics card just have a check with the graphics card once there may also be some problem in the graphics card some IC might have burnt out in that ...
just once you remove the graphics card and insert it again and then try switching it on ...
if the video adapter IC is burnt out then you need to get replaced that by taking your motherboard to the motherboard technician ..
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | ASUS P4S800-MX Motherboard
Blue and Ywllow ghost
Hi, you need to replace the convergence IC`s and any burnt resistors in front of the IC`s, common with all big screen rear projection tv`s, if you attempt to do this yourself be sure to get original IC`s or your just wasting your time, and it will take you 2 hours easy, any questions email me back, BMW Rider
Dec 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Motherboard keeps frying. Original and replacement have both gone bad. Any help appreciated.
Have you checked to make sure your power supply hasnt got a fault. In the event of a motherboard fry up, the power supply should be checked and if in doubt change.
Dec 02, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
DS35520
maybe, try replacing the IC
Jul 05, 2007 | Sanyo DS35510 35" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
