Question about Sewing Machines
The stitching is stuck on 0 length
The fabric does not move along, so the stitches are on the same spot, no length.
  • William Gilbert Apr 03, 2015
    Hi Ariane Gravenor, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What Make and Model?
    Do you have a Manual??
    New Friend:
The first thing to do is make sure the feed dogs are supposed to be feeding the fabric through. Check the lever or button that raises and lowers the feed dogs. Make sure it is in the position for ordinary sewing. If it is not, then move it to the correct position. Then, without any fabric under the presser foot, turn the main shaft of the machine by hand and watch the feed dogs underneath the presser foot. Don't simply look down at the dogs. Lower your viewpoint so that you're looking from front to back just SLIGHTLY above the horizontal level of the sewing deck. While looking at the area right where the feed dogs are, watch to see if the dogs a rising SLIGHTLY above the level of the deck. If they aren't, and if the feed dog lever is in the correct position for ordinary sewing, then something is out of adjustment or is broken. If you are not mechanically inclined or if you are totally terrified of opening up your machine to take a look, you'd better take it to a shop and let them do it.
Posted on Apr 03, 2015
Won't ewd fabric through. It just stays in the same spot.
Google make find mfg's website and get tech support . or take it to a repair shop .
Dec 25, 2016 | Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
Feed dogs will not engage. What to do?
Are the feed dogs in the raised position and not dropped for darning for free motion quilting? Is the stitch length set to somewhere between 10 to 12 stitches per inch? If the stitch length is set too close to zero, the feed dogs will barely move the fabric causing it sew in the same spot.
Feb 21, 2016 | Sewing Machines
The little Teeth/feeder under the foot doesn't push the fabric out. The fabric doesn't move
check where the direction button/lever is
it controls the feed mechanism and if it is in the middle the teeth will just go up and down
set it one way and it moves forward and set the other way will go in reverse
it is graduated to provide a stitch length ( number of stitches per 1")
Oct 23, 2015 | Sewing Machines
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Mar 12, 2015 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
