Question about Drills
Drill keeps stopping put new brushes in if I tap chuck end it starts up
  • Drills Master
  • 1,929 Answers
There is one or more defect collector in the ancre the commutator place a resistance measure on the both brushes on the ancre and turn slowly the chuck then there is a place that wil measure nothing or great difference in resist , replace a new ancre (if its a FESTOOL < DEWALT< BOSCH FEIN or MILWAUKEE or other quality machine, and maybe also if the stator is colored dark and if measured the both poles are not in balance then also replace the coil stator (field magnet) , working with the tool at this moment made a wrong sound noise. and its eating the brushes very fast again. Have you used the drill on a generator mostly there is a problem with to high voltage , if it was then you see nothing looked like damaged only with a measure , but if it was overloaded you see different colored collectors o the ancre .
Posted on Apr 04, 2015
  • 25 Answers
SOURCE: drill chuck locked up
Your problem is with the screw holding the chuck onto the shaft. That screw if a reverse thread and needs to be tightened in reverse direction.
Posted on Apr 23, 2008
  • 313 Answers
SOURCE: Dewalt XRP Drill Chuck will not come off
you need a special jig to remove the chuck on this kind of drill
Posted on May 27, 2008
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
  • 672 Answers
SOURCE: keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Posted on Jun 04, 2010
Testimonial: "Thanks for your solution - it worked great! Robert"
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
How do I remove the chuck on my dc 725
Remove the left handed screw from inside the chuck and then fit the short end of a large allen key into the chuck, put the drill into 1st gear and tap the end of the allen key anti clockwise with a suitable heavy object.
Nov 12, 2012 | Drills
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
My drill 1/2" drill bit is stuck in my drill how in the hell do I get it to release???
Put the bit in a vise and try hittig the reverse button.If that does not work the tap the three lock tabs in the end of the chuck with a punch and you should be able to undo the chuck.
Jan 21, 2010 | Dewalt 18 Volt Compact Drill Kit
Drill is running but chuck is not turning, appears dis-connected ! Can still put drill bits in but no power to chuck when trigger pressed, although sounds and feels as if working.
This drill must have a morse taper shank on the drill itself and has to be tapped on w/ a soft face hammer to seat it on the morse tapered shaft on the drill. clean the taper really well on the drill end and the taper inside the drill chuck and tap together.
Mike
Oct 19, 2009 | Drills
I cant get the drill to open up to remove the bit. What do i do?
Your chuck is jammed. You can use a punch that is the same size as the jaws and a small hammer. You can tap the jaws back with the punch ever so slightly. Tap on each jaw the same amount of times. Start on one jaw with one tap, then to the next, and then to the third. After tapping each try to turn the chuck to open. This will dislodge the jaws slighlty and you should be able to move it. Keep doing this until you can open the chuck or remove the bit. After removing the bit spray some lubricant into the chuck and work it back and forth the whole length of the jaws. If this does not work you can put the bit in a vise and use a rubber or soft end hammer to hit the chuck off the bit. In this case you will have to replace the chuck. There is probably a bad spot in the jaws that is stripped.
Oct 08, 2009 | Drills
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Inserting new drill bit
Assuming that it is this drill:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/7144-04_TYPE_4
You will need a chuck key - hopefully you have that with the drill. It's a little t-shaped bar with a cog on one end. You put it into the holes in the chuck (the part at the end which grps the bit) and turn anti-clockwise to open the jaws. Place a bit in the centre and then turn it clockwise to tighten. Tighten the bit using each of the three holes in the chuck and make sure you remove the chuck key before you use the drill - keep it safe!
Sep 23, 2008 | Drills
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
116 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
