Question about In Microwave Ovens
By mistakenly I heat the egg in the oven it gets blast and after this its not getting heating but working normally
    Top Expert:
  • In Master
  • 51,587 Answers
Replace it!! then only cook eggs out of the shell .
Posted on Aug 11, 2015
Master_Tech
  • 770 Answers
SOURCE: microwave looks like it works but it doesn't heat
you will need to call a tech to come out and look at it ...there is most likely a problem in your High Voltage circuit but if you are mech inclined and have a meter to test some voltages i can walk you thru it It can also be a bad relay on the ctrl board I really cant tell until you get into it
Posted on Jan 24, 2008
  • 52 Answers
SOURCE: Microwave oven not heating
Return from store that it was purchased from. it is unfit for purpose
Posted on Feb 21, 2009
  • 64 Answers
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
Posted on Jul 02, 2009
heatman101
  • 43501 Answers
SOURCE: Amana ACM2160A 1100 Watts Microwave oven doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
56ik
Posted on Sep 30, 2010
2coolrick
  • 560 Answers
SOURCE: My samsung microwave oven is
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Posted on Oct 03, 2010
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Somebody exploded an egg in Kitchenaid Microwave combo oven, and circuitboard went bad. Power but no heat. Coincidence?
The circuit board is in a separate section so the motherboard can't come into contact with the exploded egg. Was any liquid cleaning solution sprayed inside to clean up the mess? There might be some crevices where cleaning solution spray could work its way into the circuit board section since it's very close by. Always use a damp cloth instead of saturating the oven with cleaner.
Apr 24, 2014 | GE XL1800 1100 Watts Microwave Oven
I boiled a egg in my microwave multiwave oven 750 watt and after 3 min the egg blasted and the oven stopped working. what could have happen and how can we fix it at home?
Unfortunately this is one of the worst things that can go into the microwave, when it blasted it covered everything on the inside including the magnetron and door switches. The cost will be high because chances are high the magnetron is damaged and the interior cavity is covered in egg not to mention the door latches, I would recommend replacing the whole unit.
Mar 30, 2012 | Microwave Ovens
Microoven model 860A is not getting heated
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
The keypad and clock works but the oven will not heat. and the oven makes a loud, abnormal sound when turned on. any ideas how i might get this oven running again?
If it appears to be making all the normal sounds but just a louder noise and no heat, your probably looking at a magnetron that is bad on unit. You are looking at about $100 just for the part. Hope this helps
Dec 02, 2009 | Frigidaire PLMV169DC Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
74 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
