Vrtical ic no 74040 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 03, 2015
Vrtical problem
What is the problem you faces with this TV? Vertical rolling? Vertical jitter? Provide more details please.
Jan 04, 2013 | RCA Televison & Video
42" LG plasma
It sounds like a bad panel, which is not what you want to hear. Replacing the panel on a Plasma TV usually costs more than just replacing the TV. However a bad panel causes vertical lines exactly as you describe.
Sep 10, 2007 | Sony PFM-42X1 Plasma TV
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Aug 20, 2011 | Akai Televison & Video
My digistar tv does not turn on but the red standby light is on
If this is a standard TV, I would be searching for a bad start up capacitor. I always search for a 160 volt to 200 volt at 1Mf or 2.2Mf. These go down in a hurry. They are usually you standby cap and also operate the horizontal deflection. Also look for a 160 volt to 200 volt 4.7 Mf capacitor, these go bad as well. Second, be sure you have good grounds on your vrtical IC (LA 78XX series). You may need to resolder these pins, do not short them together with excess solder. You may resolder the large flyback transformer, sometimes a bad ground here, will not let your TV come on. I have not repaired this particular model. But I would certainly start with the info I give you. Thanks for asking and show all hands of support!
Jul 05, 2011 | Televison & Video
I have a Sansui TV model DTV3200. Vertical foldback. Replaced vertical IC LA7847---did not solve problem.The CRT is fine. Thanks for any assitance you can give me.
fold back means u have to check power supply to v/ ic 25v. if it is ok,,, u have tochange all capacitors in vrtical section,, sometimes feed back resistors may be fauty,,check them also
Mar 19, 2010 | Sansui DTV3200 32" TV
Toshiba CE35f15 TV
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Sep 29, 2008 | Toshiba Televison & Video
Lcd monitor
Email rhartze@key-services.com with model number and your telephone number. He will call you back.
Jan 08, 2008 | Planar PC White 17.4 in. Flat Panel LCD...
Is my t.v dead???
no, not atall may be vertical section problem, check vertical sction crcuit, check all the capacitor and ics at vrtical section .../
Oct 08, 2007 | Televison & Video
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
