Question about Cell Phones
Charging port came loose inside egrip, wont charge
yungdub
  • 93 Answers
SOURCE: Charging port on LG Voyager loose
time for a new phone or some super glue
i suggest you not play with the phone as much when its on the charger
Posted on Jun 14, 2009
SOURCE: the charging port inside the phone is loose and
my old one did that, i researched it and talked to my friends who had had them too and apparently its a pretty common problem if you take it to thestore they'll tell you its either water damage or your port is rusty i finally gave up when my second chocolate did the same thing so i got a universal charger. you take out the abttery and put it in the thing that goes into an outlet. it works and your phone will hold charge longer but you do have to turn it off and put it in. hope i helped =)
Posted on Sep 08, 2009
  • 155 Answers
SOURCE: LG VX9900 IT WILL NOT CHARGE I THINK THE CHARGING
Hello
Before you conclude that its the charging port i think you need to test another compartible charger and see if it works or you could open your phone with a phone screwdriver and dust the charging port and try it if it works.If it doesn't work then you would need to replace the charging port.Temporarily you can use a desktop charger to charge your batterywhile the port is being replace.
GOODLUCK
Posted on Jul 03, 2010
SOURCE: charging port lg chocolate
wow to soder the charger port for lg vx8500
charles
Posted on Aug 22, 2010
  • 4102 Answers
SOURCE: my charging port is either broke or loose on my
Hi, the charging port will need replacing this can be done at a cost, it would be worth getting done for that phone but the cheapest option would be to take it to one of those small independent phone shops and ask them about the repair, these will charge a lot less than the bigger branded shops and they should be able to get it done a lot quicker as they wont need to send the phone off.
this repair is worth doing for that phone so have a shop around and see what prices you can get, are you sure the problems is with the port and not with the charger, take the phone into the phone shop and ask them to test it for you to tell you if its the port or the charger they wont charge for telling you this but at least then you will know exactly what is at fault.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Nov 10, 2010
My daughters tabeo charging port is loose and wont charge how do i fix it?
I would take it to a tech. before it gets more damage
Dec 17, 2014 | Toys R Us Tabeo
Fix loose charging port
You will need to take the laptop to a qualified service shop to have it repaired. Usually, the charging port is held onto the mainboard by small solder connections. If the charging port is loose, then these solders have likely been broken. You can try to fix it yourself, but you wil have to disassemble the laptop and re-solder the charging port back in place. If you are not comfortable doing this yourself, then you should take it to a service shop for repair.
Hope this helps!
Joe
Dec 24, 2013 | Computers & Internet
Charging port won't recognize charging cord
The port may have come loose inside or has become damaged. OR
The charger may be bad.
If the port is bad it is noticable with the charging cord inserted:
It may have free play movement or wiggle
Dec 01, 2013 | ESD 7000 Radar Detector
Wont charge or turn on
it is a very highly chance your charging port is broken on the inside or is loose but if you know the tablet still has some charge left in it you can try holding down the power button for 20-30 seconds and see if it turns on.
Nov 12, 2013 | Samsung Tablets & eReaders
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Aug 09, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Batterey wont charge, charging port real loose. Is
If the charger port is already loose and the battery doesnt accept charge anymore then you have to replace the motherboard of the laptop. Port cannot be replaced individually,you have to replace the whole part for this issue.You can contact the manufacturer of your system and if it is in warranty then they will replace it for you.Try to check the charger/ac adapter make sure no part is damaged aswell...cheers!!!
May 08, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Batterey wont charge, charging port real loose. Is this part of the hard drive, or can the port just be replaced?
Hello Sbyv hi, a loose port will definitely wont charge your battery, but before you replace the port, check the AC adaptor DC output, and see if there is DC present.
Mar 31, 2010 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Can you share to me on how to repair of not charging in N1100
i think the charging port might have damaged or the charging IC is gone ...
just give a try with the other charger ...
if the charging port is gone then you replace the port with the new one ...
if the charging IC is gone you must get the new one and solder it ....
just have a check after opening the handset check whether is there any loose contact inside near the charging port ...
make sure of which type of problem you have and then taking the necessary steps ..
any doubts reply me
i am always here to assist you
thank you
bye ....
Apr 15, 2008 | Nokia 6600
Not charging N1100
any doubts reply me
thank you
bye ....
Apr 10, 2008 | Nokia 1100
Cell phone wont charge
Yes, it sounds like a loose charging port contacts/connectors.
Dec 05, 2007 | Motorola Mobility V262
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
