Question about Cakewalk Music Creator 5
When I try to record on any track the playback sounds crackly with eternal echo. Tons o feedback with levels low.
Win 7 HP G60-635DX Laptop
  • 5,391 Answers
Sounds like a connection problem. Possibly an earth wire touching or broken.
Posted on Apr 30, 2016
Sound noise feedback during recording
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Jan 15, 2013 | Computers & Internet
Sound noise feeback during recording
b>
Jan 15, 2013 | Logitech Webcam
Sony laptop when opened and on the speakers squeal! The only solution to stop the speakers from squealing is to plug in an external headset. The squealing sound doesn't come through the headset....????...
It sounds like you have FEEDBACK
Open volume control.
When the box with all the sliders opens up click on OPTIONS (top left)
Click PROERTIES
Tick RECORDING then clck OK
The slider box will swap to the RECORDING slider box
Select the one you want to use as the recording SOURCE and put a tick in the box at the bottom.
NOW check that you dont have the microphone level turned too far up !
done it myself before now
Now click OPTIONS once again
Then PROPERTIES
Now tick PLAYBACK and then OK
You should now be back in the normal playback slider box
Whilst you were in the properties for either recordeing or playback you may have noticed a list of devices to show them as sliders tick them
Aug 31, 2009 | Sony Computers & Internet
Can hear no sound during any form of playback
mybe she turnd off the sound try to turn it back up, on the side there are these buttons that go up and down, click on the one that goes up.. hope this helps
May 27, 2009 | Samsung Eternity Cell Phone
Logitech Notebook Quickcam (SOUND PROBLEM)
Normal 0 If you have your speakers turned up to high it will give you feedback causing distortion and static. Sometimes even awith the speakers turned down low, feedback is possible.
I recommend using a headset when videoing. Hope this is of some help. Bud
Apr 22, 2009 | Logitech QuickCam Webcam
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
I messed with my sound
echo due to playback setting on mic controls. ??
Go to sound properties and enable all slider controls both for Playback and Recording. Look at Recording sliders and mute any that you don't need (esp. Mic Playback).
Aug 03, 2008 | Acer Aspire 5610-4648 Notebook
Cakewalk Music Creator 5 Logo
615 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
