Question about Electric Health & Beauty
My bet to win 250 scooter has now electric power and battery is goid what could it be?. Fuses are ok.
  • 534 Answers
SOURCE: no electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Posted on Jul 12, 2009
  • 177 Answers
SOURCE: when charging the battery for the mongoose m200
Hi. Some scooters have a circuit breaker that connects the power to the controller and motor, is neccessary to have this on.
Most scooters have a lock and key to turn them on with, and in nearly all cases, it is not neccessary to have this key to charge. If in doubt, try it both ways and see what happens.
Good luck. Neil.
Posted on May 29, 2010
  • 11 Answers
SOURCE: ins50@msn.comhow do I refill the
There is a website that shows the specs of your bike named www.bikerparts.com
Posted on Jul 29, 2010
  • 692 Answers
SOURCE: Old Zippy electric scooter has little power and
Well Richard I guess there's nothing wrong if the expert said the batteries were good. Could be in need of brushes on the motor. There should be caps over the brushes that can be removed to check the brushes. If they have excessive wear say 3/8 inches long or less then they need to be replaced. But my first fix would be to replace the batteries, give them a good charge before use and see if that increases your drive time. Of course replacing worn brushes can't hurt either. Good luck hope this helps
Posted on Feb 25, 2011
gregg201
  • 47292 Answers
SOURCE: 2005 Kymco Bet and Win 250 service manual
Hi, Ralph the vast majority of service, parts fiche, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee of $15 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available and some were never printed in English. The Indian and Philippine markets are usually in E-book format only, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. If there is no $ sign after the manual link it is free to download.
To download your manual for viewing or printing please click on the blue links below. Good luck and have a wonderful day
KYMCO Bet Win 125 User Manual service manual, not owners. Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts...
http://www.scooterunderground.com/knowledge/manuals/pdf/B&W%20250%20Owner's%20Manual.pdf
2005 KYMCO Bet Win 250
Kymco Wikipedia
Posted on Mar 12, 2018
When i turn the key on the scooter, nothing happens and nothing lights up, i have checked connection and all show power, the power indicator does not move, yet batterys are fully charged any ideas TIA
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
Regards
Rob
Nov 05, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
2005 Kymco Bet and Win 250 no electrical power
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Electrical Ignition Parts for KYMCO Bet Win eBay
Couple Of KYMCO Questions
http://www.scootermasters.com/manuals/People-250-Full-Manual.pdf
Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts... http://www.scooterunderground.com/knowledge/manuals/pdf/B&W%20250%20Owner's%20Manual.pdf
Apr 03, 2015 | 2005 Kymco Bet and Win
Why wont my celebrity x3 charge
Try the Charging circuit fuses hidden under the mat and floor hatch.
Is the charger OK?
Are the batteries coming to the end of their life?
Apr 25, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
2007 Kymco Bet and Win 150 lost drive and engine stopped
Hi, Drbob585 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Motorcycle Troubleshooting Guide Four Stroke Cyclepedia
KYMCO GRAND DIN 125 Service Manual "FREE"
KYMCO BW 125 150 Bet Win 125 150 Scooter Workshop Manual Repair Manual... $10
https://www.repair-manuals.eu/kymco-bet-and-win-125-bet-and-win-150-repair-manual "FREE" Zip File
Jul 13, 2017 | 2007 Kymco Bet and Win 150
My e scooter has charge but no power any ideas
Your battery is not holding the charge, it needs Replacing. Regards Billy
Dec 21, 2010 | Electric Eyeware Kids Foldable X-treme...
Rascal scooter no forward or reverse or seat rise
Does the scooter have any power to it at all? Have you recently charged the batteries? If the scooter has been sitting unused for a while the batteries may not take a full charge and need to be replaced. If the batteries are good, check the fuses and all of the battery connections to ensure nothing has come lose. Sounds like a power issue.
Oct 17, 2010 | Electric Mobility Mobility Electric Power...
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Health & Beauty Logo
81 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
