I cant get these devices to work with my laptop
Drivers installed fine for mouse when i hooked the usb up
  • 5,631 Answers
If it is a standard new USB mouse and won'r work on your laptop, so it is not working, return it to the shop where you bought it and claim your warranty so is should be changed.
Posted on May 12, 2015
IrishDruid
  • 2712 Answers
SOURCE: Logitech M-BJ58 USB optical mouse win xp issue
Hello dcipher,
This is due to a missing Windows file called input.inf. The solution is as follows:
In Windows XP, you can use the MSCONFIG utility as described in the following steps:
  1. Click Start->Run.
  2. Type msconfig in the Open field, and then click OK.
  3. Click the Expand File button.
  4. Type input.inf in the File to restore box.
  5. Type the path of the Windows XP .cab file where you want to restore the file from in the Restore from box. If you don't know the patch, click the Browse From button to locate the Windows XP .cab file.
    Note: The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  6. Type C:\windows\inf\ in the Save file in box. This assumes that Windows XP was installed to the default directory. If Windows was not installed to the default directory, you will need to adjust the path to point to the correct directory.
  7. Click the Expand button.
  8. Click OK. If you are prompted to restart the computer, click Restart.
After extracting the file and restarting, try installing the mouse software again. You should no longer see this error message.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free holidays, meals, shopping and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
Posted on Apr 25, 2008
worldvet
  • 859 Answers
SOURCE: Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Your best course of action would be to use System Restore, based on your response above. Go back to the point where everything worked for you and don't attempt to update your driver again. If it works, don't fix it.
After that if there was something you wanted to accomplish, let us know and we can help you.
Regards,
Worldvet
Posted on Oct 17, 2008
blueextc3221
  • 15935 Answers
SOURCE: unable to connect to the synaptics pointing device driver
Go to Start -> Control Panel -> System -> Hardware tab -> Click "Device Manager" -> Find the item called Mice and pointing devices and click the + sign.
If synaptics is listed right click and select Uninstall.
After that completes go to the top of the Device Manager and select Action -> Scan for hardware changes...it should find the device and attempt to reinstall it and the driver.
Thanks for using FixYa - If you
Posted on Apr 29, 2009
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
  • 903 Answers
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Posted on Aug 20, 2010
Mouse won't work on my lenovo b560
sometimes, driver cant install bi itself.... solution:
press right mouse button on MY computer
and press manage> then press Device Manager>
then search device with ! simbol or ust press update on your mouse driver (human interface device)< press next next... and i hope mouse will work...
if not working it is your USB device fault, or Registry problem fault...
Jul 09, 2012 | Lenovo Computers & Internet
When I plug my USB mouse it dosnt work. what should I have to do?
Make sure whether USB ports are working fine or not. Or go to BIOS and check usb devices options enabled. If its enabled , restart your PC. Right click on My computer and go to manage and check device manager. If you see any yellow mark near usb devices or usb root hub you need to install chipset driver for your system mother board. If you are seeing any red mark near usb devices or USB root hub, right click on that and enable the device. If there is no mark and still your mouse doesn't work, issue with either USB ports on mother board or usb mouse.
Mar 31, 2011 | Computers & Internet
My mouse has completely stopped working. It worked fine yesterday and as of four hours ago it stopped working. Help me please. p.s. i just got the laptop in the mail yesterday
Can you borrow a mouse from someone to determine if your fault is the mouse or the laptop? Also I assume it is a usb mouse. disconnect plugs of other usb devices out and see if that helps.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 03, 2011 | Computers & Internet
My Compaq nx5000 notebook doesn't recognize an add on keyboard
Try other usb devices to make sure that your usb ports are working. If you try other usb devices and they work then you know the usb ports are working properly.
Now hook up the keyboard again to the usb port, see if the laptop recognizes it at all. if its recognizing it but not installing the drivers for it, then go ahead and put the disc in and run the setup off of the disk to install the drivers, then at that point it should work.
If that doesn't work, go to there website and download the latest software and install that.
If you hook up the usb device and the laptop isn't seeing it at all then that means the usb device is bad and your best bet at that point is to bring it back to the store and get another one.
Also make sure if the motherboard and mouse require batteries that you have good ones in there before trying to hook up the usb device to the laptop.
If it still doesn't work then you know its bad and you need to get another keyboard and mouse and usb device or go with another brand and model of keyboard and mouse.
Jan 26, 2010 | Logitech Labtec Media 800 Mouse
Mouse suddenly stopped working. Battery is fine. Cant find it listed in my devices any mor.
try to reinstall drivers
uninstall and reinstall.
see if it works on another computer.
if not replace with another mouse
Nov 26, 2009 | Logitech V220 Cordless Optical Mouse For...
Can't use a wired usb mouse
Hi, well there is a couple things you can do, first check for the usb devices in device manager, which is at control panel, system, hardware tab, device manager button and usb devices will be at the bottom, if there are any exclamation points or x's then there would be a driver problem. Chances are there is not a problem with this section, next double check your bios if you already have too, make sure in peripheral devices that your usb is enabled. Finally do some of your standard tests with rebooting the computer with the usb mouse hooked up and reboot the system with it disconnected to see what difference you get, then test possibly with another usb device, either printer or external hdd or another mouse. When you find out if its the mouse or if its the hardware port or if its the drivers, for mouse just replace, for hardware port don't use it anymore or replace motherboard, for drivers attempt either a windows repair or possibly a chkdsk since the usb drivers get installed from within windows.
Nov 02, 2009 | Toshiba Satellite A75-S211 Notebook
Installed new IRock sp7000 USB 800dpi mouse and it would not work.Updated driver. Pointer worked for a minute and no more, the scroll and the page up and down work OK but no pointer. Any Ideas. Vista OS
Hook up a second mouse.Uninstall the device completely after disconnecting. Reboot twice.
With the second mouse still installed, run the software to install the IRock, only using the new driver if possible. Leave the other mouse hooked up and reboot. It should work from there.
Sep 04, 2009 | i-rocks SP-7000 (SP7000SL) Mouse
Same problem...
get a new keyboard at walmart they are only about 12 dollars
Jul 02, 2009 | Logitech LX 300 Keyboard/Mouse
Dell latitude C840
try using the usb mouse then go into control panel>system>hardware>device manager. Click on the +sign next to touch pad or pointing devices and right click on touchpad, then click on uninstall. Reboot the computer, unplug the usb mouse and the touchpad should be picked up as new hardware and be re-installed.
Dec 08, 2008 | Dell Latitude C840 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
