Question about Soleus Dehumidifiers
Manual for sg deh 25-4 dehumder soleusair powered gree gives instructions on how to operate
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
I have Soleus Air, Powered by Gree.Modei# sg-deh-30m-1 .S/N 54930000806. Is on a recall? dehumidifier
call manufacturer or store and ask using make ,model whwn and where bought
Jul 27, 2017 | Soleus Dehumidifiers
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
How do I find an exploded view of a LX-140?
SOLEUS PORTABLE Parts Model LX 140 Sears PartsDirect
Sears has a diagram that if you click on it will expand it and you can pan around. If that isn't sufficient, you might try emailing the distributor directly: email to contact@soleusair.com
Jan 16, 2015 | Soleusair LX-140 14,000 BTU AC and 14,200...
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
This dehumidifier continues to run after it is full, spilling water out of the full tank. How can I fix this?
Diane, the float valve in the left top of the bucket (it's styrofoam) is stuck and can't shut the unit off when the bucket is full. To help you solve this, I am providing a link to your Owners Manual that will help you with this problem You can download and print the manual for future reference Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to solve this problem.
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Hope this helped you to solve the problem. Please take a moment to rate my response to you.
Thanks.
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Soleus CFM40E
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Dehumidifiers Logo
107 people viewed this question
Top Soleus Dehumidifiers Experts
Gil Shultz
Terry Hair
 Russ Hill
Russ Hill
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
