I have a new lid for my washing machine but I can't remove and install the new lid. How do I get the old one off and the new lid on?
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
Also check this link to get a detailed idea related to your issue:-
Please get back to us if you have further query or else please accept the solution.
Hi One of the most common problems with washing
cases, just the balance of the load can cause the machine not to spin. Examine the lid switch for wear. Replace a
wires before removing the old switch. Insert the new switch in it's place. Look for excessive glazing or cracks on the
to pull the belt around and into the pulley. Replace the washer's motor by firmly grasping
motor's wiring harness. Replace the washer's pump by removing the
related to your issue:- Please get back to us if you have further
query or else please accept the solution. Thanks for contacting fixya.com
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Hi
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
Then check for lose or worn or crack in belt. If these signs appear, remove the old belt by tipping the washing machine over on its side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
