Question about Samsung RFG298HDRS 28.5 cu. ft. French Door Refrigerator with 5 Spillproof Glass Shelves, External I
Water and ice dispenser no longer work. Changed filter. Self test has 88. Everything else works fine.
  • 20 Answers
Line is frozen, lower temperature for 24 hours, This should fix, your problem
Posted on Apr 05, 2015
tborn6
  • 700 Answers
SOURCE: Not getting any ice
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Posted on Dec 21, 2008
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
beamerguy740
  • 65 Answers
SOURCE: My new (2 months) Samsung refrigerator barely
The only thing between the inlet line and the spout?
Water Inlet solenoid, a valve that lets water in. Follow the inlet line to the back of frige. Unplug and turn off water before service. repace valve. EZ FIX...
Posted on Mar 29, 2010
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
  • 2069 Answers
SOURCE: Samsung RFG295AA Ice maker
You could try to Reset the ice maker. there should be a red button by the side of the icemaker. After resetting, wait 24 hours and check if ice production has begun. please also check this very useful guide on how to get on otherwise.
If your ice maker still doesn't produce ice after following all of these suggestions, schedule your unit for service
Posted on Jan 06, 2011
Water stopped coming out of the dispenser and it no longer makes ice. I checked water supply to the unit and everything was good. I have replaced the water filter.
Hello friend, thank you for your post!
From the information you have provided there is no water coming out of the dispenser or ice of your Frigidaire refrigerator. I see you have changed the water filter and still have no water flow. This could mean there is a clog within your water line or your water valve may not be pushing water into your refrigerator. You may need to seek assistance from a technician. They would have the appropriate tools needed for proper testing and disassembly of your refrigerator. This will help prevent any personal injuries or improper part replacement on your refrigerator. -Matt
Jan 04, 2016 | Frigidaire Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Problems with ice maker and water dispenser
Sometimes the water line entering the freezer will freeze up, if it is you can melt it with a hair dryer. If that is not it you will need to test the solenoid valve under the refrigerator for power, if so you can remove the water line on the outlet of the valve or the inlet of the water filter, when you push the water lever water should squirt out of the hose, if not the valve is problem bad.
Mar 17, 2014 | Whirlpool Refrigerators
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
Water dispenser is dispensing water at a trickle
The water filter is the first item I would check. I just repaired a s/s with the same problem and it was the water filter.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Samsung RFG298HDRS 28.5 cu. ft. French Door Refrigerator with 5 Spillproof Glass Shelves, External I Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
